Re: Pro Tools First 2018.7 Xpand!2 Presets Missing
Still being bundled with a free version you’ll only get a taste of the presets to show you the potential of the plug. Btw, is that a screen shot of your Xpanda2?
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
The first 3 at the beginning of the thread are mine, the last one was from a youtube video . I am doing another install. If I am still not lucky, I'm going to try to copy the files you said are the correct ones to my docs folder and see if that works. |
Good luck sometimes a reinstall can work too.
Can anyone help here? I have the exact same problem. How do I resolve it?
What ver of PT are you running and on what sys Mac?, Win?
#16
I’m using Protools First on windows 7.
#17
hmmmm Windows again..... was it working previous or have you only just did the initial install?
#18
It's all working except I don't have any presets. I'm trying to lay down a drum track but I can't because the presets are missing. This is a new installation.
#19
perhaps if the OP could chime in and see if they were able to rectify the issue.
#20
I am closer to resolving this, but I need to know which location the .tfx and/or .ptxp files should be in (I believe the .tfx files are the preset files).
There is an issue in the installer where it is not installing or extracting the Xpand!2 preset files. I went to AIR's website and downloaded a trial version of Xpand!2, which is the same package that should be supplied with PT First. Finally I got a bunch of preset files! They installed to C:\Program Files (x86)\AIR Music Technology\Xpand!2\Presets. I copied the files to C:\Program Files\AIR Music Technology\Factory Content\Track Presets\Avid\AIR Instruments Bundle\Xpand!2 but still do not get presets loaded when I open Xpand!2 in PT First. Does anyone know the location, for Pro Tools First, where the .tfx files should be located? |
Presets missing from Xpand!2 | [email protected] | Virtual Instruments | 9 | 05-25-2019 01:20 AM |
Xpand 2 - missing presets? | TLK Tom | Virtual Instruments | 10 | 03-29-2019 09:49 AM |
PT 2018 Xpand2! Missing presets and disappearing MIDI input | Harleyman | Windows | 1 | 03-17-2019 02:30 AM |
Pro Tools First 2018.1 Missing EQ Graph panel | Jakeman | Pro Tools | Intro Discussion | 5 | 02-06-2018 08:00 PM |
