Re: Bug?: Import Session Data Window Too Big
440Hz Yarra Valley, Melbourne, Australia ------------ Mac Pro 2,1 Dual Quad Core 3GHz 18 GB RAM OSX 10.9 Maverick's 3 x 1TB SATA 1 x 250 GB SATA (Seagate) PT 12.6.1 HD MC MIX RME UFX, Ferrofish A16 AE MIDAS Venice 320 -------------------- "The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs. There's also a negative side." Hunter S. Thompson |
Anyone...?
If your OS supports "Double Click on Title Bar...", this will maximize the Import Session Data window and enlarge the Match Tracks area.
Usually this also moves the "OK" button below the screen edge, so you need to double click the top bar again when done to Cancel or "OK".
Brian Dozoretz ACSR ACI Dolby Atmos Mac Pro, os12.6.3, PT 22.12 HDX, 2xAlphalink,1xDeltaLink, Mac Mini, os12.6.3, PT 22.12 HD Native + HD Omni, Artist Series Mix x 2, Artist Series MC Transport, Atmos 5.1.4 VENUE SC48 3.2 with iPad Control SSL Duality SSL Duality via ipMIDI / ∂elta Automation Plug-In |
Where would I find "Double Click On The Title Bar Option'? I tried to double click on the Import Session Data Window title bar but nothing seemed to happen. Cheers Nic
Mac OS El Capitan and Sierra:
https://support.apple.com/kb/PH21915...ewlocale=en_US Sent from my iPhone using Tapatalk
#16
#17
Hey Brian,
Thanks a bunch for the links. I've found a workaround thats pretty annoying but workable. The double click thing doesn't seem to work as it seems to make the Import Session Data window so large that I can't access the 'DONE/Cancel' button at the bottom of the window as it's disappeared off the bottom of my screen. If I temporarily change the screen resolution in system prefs I can view the session data window, make my selections, then change the resolution back... total PITA
#18
I had the same problem with Pro Tools 12 in Windows 7. Changing the resolution did not help, but I found a solution by changing the orientation from landscape to portrait, which flipped the screen on its side, making it long enough to fit the window I had opened. It was awkward to work the mouse, but once I completed the settings on the window, I closed it, set it back to landscape, and everything worked.
match track in Import session data window issue | dgoodi22 | macOS | 5 | 09-06-2013 12:35 PM |
Import Session Data window scroll | Vedat | macOS | 0 | 07-31-2012 06:28 PM |
10.1.1 Import Session data window size bug? | meech | macOS | 0 | 03-27-2012 09:25 AM |
import session data without audio data | rgalpin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-06-2010 01:49 PM |
FR: resizable import session data window | travista00 | Pro Tools TDM Systems (Mac) | 5 | 09-01-2009 05:58 AM |
