Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 07-02-2008, 01:16 PM
theaero theaero is offline
Default If you have a mac and a profire 2626, could you please help?
Hi, if anyone has a mac and a profire 2626 and is running windows XP using bootcamp, could anyone run a quick test for me? could they install service pack 3, and then install the new service pack 3 driver for the 2626 and let me know if it works? I would done this myself, but i *just* installed vista before I noticed the new XP sp3 driver. The new vista driver works with the 2626 which leads me to belive just maybe the sp3 xp driver will too. So if you are a fellow 2626 / Mac user who wants to use the 2626 on XP, or if you just wanna help me out, please test this out, and let me know the results! Thanks!
Old 07-06-2008, 01:45 PM
Andi Andi is offline
Default Re: If you have a mac and a profire 2626, could you please h
thanks for the heads-up, hadn't noticed there were new drivers.
I'm pretty happy with the OSX performance, but I might switch to use Chimera and other VSTis.
I'll try asap.
Old 07-06-2008, 02:15 PM
unfortunately, I still get a code 10 on the second part of the installation process.
2.4 GHz macbook pro, Win XP SP3
perhaps someone else has more luck?
Old 07-07-2008, 04:26 PM
I tried as well (just made a new XP parition)
Works just fine on Vista 32bit (Which are the EXACT same drivers as the SP3 XP drivers), but it didnt work on XP sp3. (Mac Pro 8-Core)
Also a lot of people are getting this error even without boot camp and it is being addressed on the M-audio forums and also mentioned by a couple people on gearslutz. Hopefully we will get a fix ASAP.
Thank you btw for testing the drivers.
Old 07-11-2008, 11:30 PM
bgaston bgaston is offline
http://duc.digidesign.com/showflat.p...91#Post1299591
This might help you guys out. Seems like you are having the same problems I had.
Old 07-14-2008, 01:32 PM
thanks a lot, looks promising. I'll see if I can get the drivers.
ProFire 2626 lrankine Pro Tools 11 3 05-25-2013 06:32 AM
PT MP9 & ProFire 2626 Rjones17 Pro Tools M-Powered (Mac) 0 12-04-2012 11:48 AM
Is the Profire 2626 more stable than Profire Lightbridge? (PT8 or snow leopard?) tomv-k Pro Tools M-Powered (Mac) 5 03-09-2012 02:45 PM
Can this be done with the profire 2626 boabyd23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-03-2010 10:05 AM
Help with profire 2626 guitar486 Pro Tools M-Powered (Mac) 13 12-31-2009 03:19 PM
