AAE error -30002 was encountered
Hello
I got my very first "crash" on my very new system HDX this morning First one is when I disable a Master fader plugin (FabeFilter Limiter) and try to re-enable, Pro tools tel me that he couldn't because this plugin is not in my plugin folder (but it is I'm sure I buy all the master bundle from Fabfilter) So I decided to restart Pro Tools And when I reload my session all my plugins won't load this time ! (not found in the plugin folder !!) I try to re-enable some of them but got this message "The plug-in could not be made active because an AAE error was encountered AAE error -30002 was encountered " I repair Hd system permission and maybe will try to reset preference un Pro Tools … but I'm a bit confuse here Any Clue out there? Thanks My rig details are on my signature and I'm on 10.15.6 Catalina, Last Version of ProTools today 2020.9.123
Owner of www.studio-up.be Pro Tools 2020.11 HDX Sonnet Thunderbolt 3 Rack enclosure with a Mac Mini 2020 I7 64Gb of ram And Avid Dad Mtrx Studio … Last edited by cerisaie; 10-24-2020 at 05:05 AM. Reason: Adding some Spec |
Re: AAE error -30002 was encountered
Second: 65 gig of ram is not possible. Must be 64 gig. Along with that there's no such thing as a Mac Mini 2020 as the last models are 2018's. Third: I'm confused with your PT version. Versions are usually referred to as something like this: PT 2020.9 (no need for anything past that) All that being said when you installed the plugins did you let the installer put them where it wanted to? Are you running as administrator? |
Thanks for trying to answering me Musicman691 !
For the point 1,2,3: My spec details are on my signature and you're right 64 Gb is what I have (I'll correct that) For my operating System : I'm on 10.15.6 Catalina, Last Version of Pro Tools 2020.9 (.123) those numbers are indeed useless I run all my package as administrator I always had to write my admin pass (I install Diamond Bundle from Waves, Plugin Alliance, all the bundle included with my DAW, and the mastering Bundle from Fabefilter, Reason Rack 11 , plus extra other plug I buy like Kazrog True Iron for example… ) You right I just do a "First aid" of the disk system that doesn't mean it solve my authorisation I'll check that too Cpu Usage 9% iddle 37% in play Memory 10% HDX card 11of 18 slot used (but only average 70% full ) Thanks again !
Owner of www.studio-up.be Pro Tools 2020.11 HDX Sonnet Thunderbolt 3 Rack enclosure with a Mac Mini 2020 I7 64Gb of ram And Avid Dad Mtrx Studio … Last edited by cerisaie; 10-24-2020 at 05:43 AM. Reason: More information abour System usage |
Gentle little Bump and a complement info It seems to occur when I'm using de version DSP aax off my Brainworx bx_console Focusrite SC so I guess it is a question of bad programming here … Hope they will improve that in the future
Owner of www.studio-up.be Pro Tools 2020.11 HDX Sonnet Thunderbolt 3 Rack enclosure with a Mac Mini 2020 I7 64Gb of ram And Avid Dad Mtrx Studio … |
AAE error 30002 with drumagog 5 platinum | funkmasta | Windows | 2 | 04-06-2018 05:55 PM |
Help! I get the error 'pro tools has encountered an unrecognized component' error | gsmith135 | Windows | 10 | 12-17-2014 01:08 PM |
DAE error 720 was encountered | Labbe de Montais | Pro Tools SE and Essential (Mac) | 5 | 05-06-2013 06:48 PM |
DAE error 7 encountered. | Smoovie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-22-2004 07:55 AM |
DAE error was encountered while trying to connect (error #-7101 | Enis Presheva Jr. | Pro Tools TDM Systems (Mac) | 1 | 06-07-2001 12:45 AM |
