Best Optimization For Windows7 Core I7 PC
Hello all . . .
I was wondering what the best optimizations were for a core I7 PC under Windows7 64bit. I have a pretty fast PC: Core I7 2.6ghz (Asus P6T Deluxe) with 12Gb of Corsair Dominator running in triple-channel mode. I have a 130GB SSD as my system drive a Seagate Cheetah as my sample drive, and a regular 7200 WestDig as my audio drive. My video card is an ATI 5770 I am running Windows 7 64bit witha UAD 2 solo, and a UAD 1 PCIe. I can do a lot with this system but I get "Out of CPU" errors quite frequently. This si frustrating in that my CPU is never shown going anywhere near 50% when many of these occur. I also get a lot of "Access Violations". Why is this? How fast does a native system have to be to never encounter errors such as these? Is this a virtual memory issue? Can I allocate more memory to pro tools (I have tons of it) . . . are there some tweaks I am missing . . . or is this just a "Get Pro Tools HD if you want rock solid performance" kinda issue? Any help would be much appreciated. Thanks, Justin |
Re: Best Optimization For Windows7 Core I7 PC
Gotta love the search.
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
Thanks. . .
Ok, most of those things I have already done. I guess what I am looking for is someone with experiences similar to mine to tell me how they solved their issues, or whether or not they are solvable. Is it expected for a system as robust as mine to have access violation errors (ever, occasionally, frequently)? How does virtual memory allocation in Windows 7 64 effect Pro tools operation? I am looking for anecdotal information relating to my issues. Again, any help would be appreciated. |
I believe SSD's have not been qualified just yet, but again its all speculation until we see how your configured. You should be running smooth with your systems capabilities, perhaps its just a matter of configuration. Also, what interface are you using?
PT11, Windows 10 RME Babyface
Justin
I feel your pain. I've got a similar system to yours and I occasionally get out of CPU errors but less now after I did the basic optimizations and a few others that I discovered along the way. When I get the out of CPU errors now, it's indeed random and a lot less frequent. BTW - I also had the same errors before upgrading to Win7-64 and PT9. Speed and power doesn't equate to better behavior with Pro-Tools. Goes against common sense but that's the way it is. I've been meaning to capture in a list the things that I've done to tune my system so your post gave me the perfect excuse. Here's a list of things you can do just to ensure that your system isn't being hijacked by some system process or Windows "feature". 1) As Cloud_9 mentioned, the optimizations are a must. You should do them all including disabling the network interface. I'll explain that later. I'm sure there's other things I've done but these are the big ones and they took the most time to do. If Microsoft ever "fixes" Windows 7 and brings back hardware profiles, then you'll be able to configure your machine to have a split personality, one for day to day computing and another dedicated to music production. For now you have to kind of take away all the glitter and disable the items that your don't really need. Hope this helps. Alain |
Now we're talking . . .
Thank you very much. I consitently get -9128 errors when I open a big plugin window (like Guitar Rig for instance) at lower buffer speeds (64, 128) . . . I will try these tips and see if I can reproduce these over-runs. Thanks again! Justin |
This is the kind of stuff that makes me say "You have to be kidding. I need to go through ALL of that to make a piece of software work that should work right out of the box?" This is ridiculous.
I guess I will just go back to Sonar. |
It works fine here using nothing but the high performance power settings.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
not sure it will help but make sure your cores are not parked.See the you tube video on ''core parking''
Add this to the list of BIOS tweaks; disable floppy drive(drive A:) Re these 2, I must offer my own 2 cents in blue: 14) disable onboard audio if you've got any. Most of us have way better sound capabilities and there is really no advantage to having more hardware enabled than you need on the mother board. Especially not another sound card. I have never done this and always use the onboard audio as the default for all non-PT audio. Currently, I feed the mobo's optical SPDIF output to a Presonus Central Station and never had an issue. 15) defrag your physical hard drives often. Not everyday but at least once every two weeks. I've been running PT for almost 10 years and have not defragged any of my drives in several years. My system drives are rarely very old as I constantly rotate between a few drives, cloning and updating so that I always have the previous config available by a quick drive swap. Audio drives generally have any important sessions backed up to externals or DVD-R(usually both) and defragging doesn't seem to offer anything(again, this is my 2 cents only). NEVER allow any drive to get more than 80-85% full.
PT9, Windows7, PreSonus 16.4.2- need help | wordmanjay | Windows | 19 | 02-29-2012 07:13 PM |
PT9 on HP DV-6 windows7 64bit? | Kissa3 | Windows | 12 | 02-25-2011 10:50 AM |
ASUS P6T WS/ i7/ windows7/ HD2 PCIX core and accel | itguy | Pro Tools TDM Systems (Win) | 2 | 02-25-2011 06:20 AM |
How to get from PT7 to PT9 on windows7. | jacub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-16-2011 01:53 PM |
Windows7 versions | tmfergus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 11-28-2010 09:29 PM |
