Optical Preamps inputs for DIGI 002 in stand alone mode?
Is it possible to use the optical input on the DIGI 002 for more mic preamps when you are in standalone mode for stereo inputs 5&6. I've played with the wordclock settings, but nothing seems to work. Any help?
Re: Optical Preamps inputs for DIGI 002 in stand alone mode?
Inputs 5-6 don't having any relevance optical so no if I'm reading u correctly...
And what wordclock settings are you referring to? The 002 has no wordclock ports.
I'm wondering if he is asking if he can use the SPDIF connectors as analog inputs? I'm a little confused as to what he's actually asking.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
I believe we all are
I think he's asking if he can hook an external stereo pre to the 002, in stand alone mode, via the SPDIF input. Assuming that it would route to inputs 5-6. I believe the answer is no. I think you get the 8 analog inputs and that is it. If your pre has analog outs you could plug those into two of the analog inputs. Yep just checked with my 002. Looks like you get the 8 analogs and that is it.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Digital Audio Connections in Stand-Alone Mode Digital Inputs In Stand-alone mode, you can set Inputs 5–6 to accept S/PDIF digital input instead of analog input. When Inputs 5–6 are set to S/PDIF, the 1/4-inch analog connectors for Inputs 5–6 (on the back panel of Digi 002) are inactive. To set Inputs 5–6 to S/PDIF digital input: 1 In Stand-alone mode, press the Utility (F1) switch. 2 Press the illuminated Channel Select switch under Pref. 3 Press the illuminated Channel Select switch under In56 (Inputs 5–6). 4 Press the illuminated Channel Select switch repeatedly to toggle Inputs 5–6 to Analog or S/PDIF. 5 Press the Escape (Esc) switch to exit Input 5–6 preferences. 6 Press the far right-hand Channel Select switch to save the preference settings. 7 Press the Escape (Esc) switch twice to exit Utility mode. I wasn't aware of this particular feature. So I think the answer is yes. The other posssibility is that he has a 003 with wordclock but no stand alone mode.
I just bought a Presonus Digimax D8 preamp and an Ultralink fiber optic cable, it should be delivered today. I can't wait to try it. We needed it for enough channels to cover drums and tracking a full band along with our outboard preamps and the 4 002 preamps.
digi 003 rack in stand alone mode? | Resonant Alien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-24-2009 10:15 AM |
Digi 002 Digital In Stand Alone Mode | rcourell1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-04-2005 03:10 PM |
does Digi 002R have a stand-alone mode? | bdlabbinit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-22-2004 11:32 AM |
Digi 002 in Stand Alone Mode ... | The Waterboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-19-2004 10:25 AM |
Digi 002 & Octopre in Stand Alone mode with S/PDIF | Seitz333 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-07-2004 12:24 PM |
