Crossfade issue
Hey guy... Been having this problem for a while and I'm not sure I understand. ...
Basically when I try to do a crossfade between to clips, it will always say"invalid audio amount"and tells me to adjust the bounds and then it will place the crossfade at the beginning of the second clip. I can't do a crossfade between to clips. I was wondering if there is a parameter I need to change? Thanks Sent from my SM-N910W8 using Tapatalk
Pro tools 11.3, Windows 7 Premium, Desktop i5 4670 3.4ghz 16G ram quad core |
Re: Crossfade issue
Re: Crossfade issue
Ok, thanks for the work around. Any idea on what could be causing that?
Re: Crossfade issue
It's not a workaround. You're getting that dialog because there isn't audio beyond the clip boundary to be used for the fade. It's physics!!
Re: Crossfade issue
Aaaahhhh. Ok. Sorry. Misunderstood. Thanks. I will try it.
Crossfade issue | Majita | Pro Tools 10 | 5 | 04-16-2012 06:01 AM |
Need help on a crossfade | djak24k | Pro Tools M-Powered (Win) | 3 | 04-16-2009 03:29 PM |
Crossfade issue? | nortstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-22-2008 04:57 PM |
