Xpand 2 and Tempo Changes
I don't know if anyone else has this problem but I find when I use tempo changes, either constant or linear, Xpand 2 produces little pops at each change. This is beginning to get really annoying as I'm getting little pops every time I change tempo and I certainly can't use a linear variation for my accelerandos etc. I don't know if I'm missing something in Xpand's settings or what. Please help!
Darius McGann Audio Designer. Engineer. Composer. 3.06gHz i3 iMac 12GB RAM Snow Leopard 10.6.4 Pro Tools 8.0.4 Vienna Instruments Special Edition Vienna Instruments Soprano Choir Mbox 2 Mini 1Tb G-Tech Firewire External Drive M-Audio Oxygen 49 |
Re: Xpand 2 and Tempo Changes
Yep, Hybrid produces the same behaviour. The issue is probably legacy and 'might' get fixed.
Aaron Mulqueen - 001 HD Native |
Hi!
I know I am replying to a post from ages ago. But just in case it might be of help to someone, I can recommend a simple workaround. I found that when I disable an FX (in FX 1 or FX 2 section of the Xpand2 GUI), the little pops/crackles completely disappear. Then, I just route the track to an aux track where I add a plugin for the effect I had disabled in Xpand2. Something like that. It's not ideal, but it does get rid of the issue. I'm not sure if it applies to all FX types in the drop-down menu in FX 1 and FX 2, but in my case, the culprit was a chorus type effect (I don't remember which Chorus it was, sorry) in FX 1. But I do remember that I also did not disable FX 2 which contained another type of effect. So, I think you can just discover which ones cause the issue by a process of elimination. |
XPand!/midi editor destroys tempo and grid | moosebox | Virtual Instruments | 1 | 04-01-2011 02:15 PM |
Need to Change tempo but without changing existing midi data tempo? | Einsteinwannabe | Pro Tools M-Powered (Mac) | 2 | 09-18-2010 06:58 AM |
Tap tempo and involuntary time shifting with tempo changing | Skiroy | Pro Tools M-Powered (Win) | 3 | 08-26-2010 10:00 AM |
Pro tools tempo wont match keyboard tempo via midi | Killah Kane | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-18-2010 01:55 PM |
Ramping a Tempo Change (interpolation or discrete tempo points) | edgarbc1 | Tips & Tricks | 3 | 02-18-2009 12:55 PM |
