Old 06-21-2003, 08:25 PM
DoubleDigit DoubleDigit is offline
Default Static/Crackling Noise
I am experiencing a crackling type noise when rec-enabling inputs. The noise is not constant, but rather seems to increase with input level. At one time it got very bad and almost sounded like some kind of lo-fi ring modulator.
It happened at first on a mic input, but then I also hear it on my triton input which is coming it S/PDIF.
It seems to only happen after I have inserted plug-ins, but remains even when I remove them. Closing the session and reloading it solves it. ??? [img]images/icons/confused.gif[/img]
Old 06-22-2003, 12:03 AM
Chaasm71 Chaasm71 is offline
Default Re: Static/Crackling Noise
What is your clock source? Are you using internal clock, or an external?
Charlie.
Old 06-22-2003, 01:57 AM
External now, but I think it was happening before I connected the Triton....
Old 06-22-2003, 02:42 PM
All I was wondering was did you have the clock setting set to internal while you were using the triton. But, if it was happening before, then that would seem not to be the problem.
Charlie.
Old 06-22-2003, 04:55 PM
yeah, I'm not sure what it could be....it seems to happen when I'm using the DVerb plugin specifically....haven't tried many others....but it stays around even after I remove the plugins....
Old 06-22-2003, 05:23 PM
PT Crackling Static Noise/Sound - Sample Rate Issue gavriil1 Pro Tools 10 5 11-27-2012 07:39 PM
mbox2 crackling/static...!!!! 5teph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 02-07-2011 09:29 AM
Crackling/static noise w/ 002 and Kore interface. JLEpperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-23-2010 07:50 AM
Need of help of Static Crackling Sound!! acuraboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2008 08:11 AM
low output noise & crackling fuzz static on outputs after years of no problems M-Link 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-14-2003 01:38 AM
