Old 03-22-2007, 09:44 AM
gai777 gai777 is offline
Default Ducking Music Bed Under Vocals
I'm trying to set up a voice-over with a music bed that will drop in volume once the vocal track is triggered. I know this is a pretty common practice in broadcasting. Does anyone have a good link or some step by step instructions for this procedure in ProTools? Any help would be great!
Old 03-22-2007, 10:01 AM
Slim Shady Slim Shady is offline
Default Re: Ducking Music Bed Under Vocals
Use a compressor with a key input on your music bed track, and set that key input to an unused bus. Then create a send to that same bus on your V/O track and adjust away!
Old 03-22-2007, 10:38 AM
Ok, I tried the procedure and still no change. Here's what I did: 1 track is the music bed (stereo) I added a compressor to the insert field on that track. I set the key to bus 1.
the second track is the v/o track. I selected bus 1 in the sends A-E field. I must be missing something because it makes sense. Any suggestions?
Old 03-22-2007, 11:42 AM
You also still have to make adjustments in the compressor as far as gain reduction etc. and that bus send on Track 2 must actually be sending level so make sure it's not set at zero or anything.
How do I get my vocals to flow better with my music? ice0-5 Tips & Tricks 7 04-05-2011 10:24 AM
need to add some fullness to vocals and music dwayne00 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-14-2006 07:53 PM
ducking vocals Mr.BossPlaya Tips & Tricks 4 10-25-2005 09:25 PM
Ideas for ducking music track? sotagear Tips & Tricks 5 03-31-2002 05:26 PM
Ideas for ducking music track? sotagear Tips & Tricks 3 08-08-2001 12:30 AM
