consolidating clip is creating audio glitches
Hi All
I am having an issue where if i have a group of drum tracks that i have edited with tons of crossfades that when consolidating a few of the tracks tend to have glitches in them, they can be easily identified in the waveform. This seems to happen on PT HD 12.4 on different computers and both Mac or Windows. Has anyone come across this issue before? |
Re: consolidating clip is creating audio glitches
Is elastic audio enabled on the tracks that you’re consolidating?
Sent from my iPhone using Tapatalk |
No it is not. I don't use it on drums.
Plug-ins can do this.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Nothing to do with plugins i don't think. More the consolidation process dealing with either crossfades or elastic audio.
It seems upon further research a common issue since PT 11 so I am sure someone from Avid must have a solution by now. |
"The solution is to upgrade to the latest version" Signed, Avid
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Not sure that's a 100% solid solution if you cannot identify what is causing the issue.
If you can though that may be more helpful than committing to paying you $100AUD per month or learning a new DAW . |
Clip Effects Consolidating with fades and handles in tact | jondom22 | Tips & Tricks | 2 | 01-11-2019 06:50 AM |
PT crashing when creating separate clip | manyrains | Pro Tools 12 | 0 | 11-25-2016 10:33 AM |
PT 11.3.1 Freezes when Consolidating clip | gillbert1027 | Pro Tools 11 | 3 | 04-11-2016 02:42 PM |
Pro Tools freezes when creating Fades, analyzing EA, or consolidating clips [SOLVED] | Beaubien7 | Pro Tools 11 | 15 | 03-30-2015 12:54 AM |
Consolidating files creating clicks PT6.01 | MAXIMUSIC | Pro Tools TDM Systems (Mac) | 1 | 04-09-2003 02:08 PM |
