Old 11-18-2017, 02:23 PM
vidamora vidamora is offline
Default Pro Tools not opening because of file error (NEED HELP)
Could not create a new document because Assertion in "/Volumes/Development/Code/203409/ProTools/DFW/Views/UMenu.MacOS.mm", line 1639.
(Use the Copy button to copy this message to the clipboard.).
I recently updated my macOS and upon my first time trying to open Pro Tools I got this error message. Does anyone know what this means and what I can do to open a session? Thanks.
Old 11-18-2017, 02:35 PM
Start Pro Tools, hold down the ‘N’ key and when the playback engine dialog box appears select the correct playback engine... one with an output... which is likely the issue here.
I hope you installed an updated, compatible driver for your interface after you updated the OS.
You would have easily found this answer with a Google search on “assert” and the file name.
if that is not the problem, read “help us help you” up the top of each DUC page and provide the level of information described there.
Error Message when Opening AAF File seanmascot Pro Tools 12 2 06-02-2017 04:30 PM
Error when opening AIFF file LaugeJ Pro Tools 11 0 03-10-2015 04:08 PM
PT10 Error opening installation log file elovaarar Pro Tools HDX & HD Native Systems (Win) 1 11-19-2012 06:42 PM
Error Log when opening a file jon chronic Windows 0 03-16-2012 10:27 PM
Error -39 when opening a file.. Randy Wright Pro Tools TDM Systems (Mac) 3 09-01-2005 12:48 PM
