Softube Tube Tech Classic Channel...
Got my first error message ever with protools while inserting this DSP plug in a new 96kHz session. No problems with 48kHz sessionsbut this session returned the following error:
DSP couldn't be inserted due to the following error: eTIDSPMgr result_EffectcycleCountExceedsChipCapacity Sounds familiar to anyone? |
Re: Softube Tube Tech Classic Channel...
Did you download and install the latest update (version 1.0.2)?
The version has the following fixes/optimizations: This update fixes the following issues and improves performance with the Production Bundle: • Further optimized CS3, Precision De-esser, and MH MultibandDynamics, leading to an increase in instance counts • Substantial optimization of the processing code, especially for HDX, leading to increased instance counts • Fixed bit-cleanliness on bypassed CS3 blocks; now CS3 with phase invert nulls with unprocessed audio • Fixed issue with grunge when DSP is filled with MH Precision De-esser • Accurate Cycle Counts for all plugins on HDX • Enhanced control surface page table layouts • Fixed some corner case bugs that apparently can cause a DSP crash on heavily loaded systems • Additional interpolation of various parameters in the plugins to provide glitch free parameter changes • Fixed a conflict between CoreGraphics and DAE that can lead to DAE errors (DSP + Native), CPU spiking & overloads (Native) • Fixed a filter stability issue for high session sample rates for CS3 • Fixed an issue where the average trace in the analyzer view can get stuck • Reduce the size on disk and in memory of the plugins • Fixed some missing control surface metering support and clip detection • Fixed some small graphic anomalies • Fix for detector for classic compressor in CS3 when Side-Chain filter is enabled • Signed installer for Mountain Lion compatibility
********** Main DAW: MacPRO 7.1, 16-Core Xeon 3.2GHz, 196 GB RAM, OSX 10.15.2, HDX3, PT 2019.12 Ultimate, 2x UAD-2 PCIe Octo's, Raven MTZ, 1x HD Omni, 2x HD I/O's, 1x MTRX and some more cool stuff... Auxilary DAW: MacBook Pro with Retina Display (2012), 2.6GHz quad-core Intel Core i7, 16GB RAM, OSX 10.13.6, PT2019 Ultimate, 1x UAD Apollo Quad Audio Interface /w Thunderbolt Interface (v9.x) ********** |
Softube...Not metric Halo
Gets confusing when we got only 2 |
Ups! My bad ........ erm ...... sorry! I'll visit "Reading 101" class...
I Know. Didn't expect a Softube error. Just assumed it was ....
I'm sending them a report now |
Reply from Softube:
Hi Cliff, This is a expected behavior. The Classic Channel for AAX DSP uses to much cpu to run in frequencies higher than 48kHz. Here is a chart of DSP usage: http://www.softube.com/download.php?p=AAX_DSP_Chart Regards, Mattias |
WTB Softube Tube-Tech CL 1B Licence | TrentWilliams | Buy & Sell | 4 | 03-18-2014 11:51 PM |
FS: Bomb Factory Classic Comps, softube | crandallwarren | Buy & Sell | 5 | 02-19-2014 09:17 AM |
WTB: Softube Tube-Tech Classic Channel or components | RaySoul | Buy & Sell | 0 | 02-14-2014 12:57 PM |
FS: Waves Platinum Bundle V9, Softube Amp Room Bundle, CLA Classic Compressors | jlennon38 | Buy & Sell | 3 | 12-19-2013 06:56 AM |
Tube-Tech CL-1B PLugin for $329 from Softube | crizdee | Pro Tools TDM Systems (Mac) | 18 | 10-02-2009 01:41 PM |
