Old 12-20-2002, 12:13 AM
B. Randall Carter B. Randall Carter is offline
Default Sonar to PT to CD
I just had a friend come by with a Sonar file in stereo that we converted into PT. I am pretty new at this but we got the file in and working. I did some edits and added some compression and then...I realized that I don't know how to mixdown to CD from ProTools.
I realize that this is a question that can probably be answered by doing a search, but ever since the forum got back up I just get a blank screen when I perform a search in DUC. I have already poured through the manual, but I can't find the answer there either.
I don't know if it makes any difference, but I am using Nero software. I will be grateful for any thoughts that anybody has. Thanks for your time.
Old 12-20-2002, 12:25 AM
Bastiaan Bastiaan is offline
Default Re: Sonar to PT to CD
With the i-beam, select the part that needs to be bounced, or dont select anything (then everything gets bounced)
choose file/bounce to disc.
choose wav or "bwf"(if you have pt5.3.1)
choose stereo-interleaved/44.1 Khz/16 bit
You could get some trouble with Nero if you dont have the latest version. Nero will then tell you this is not a file that can be burned. If that happens, either upgrade nero, or open the resulting wav-file in another editor, and save it again. (Protools places additional info in the file, and nero doesnt know how to cope with that. Opening and saving it in another application will remove this info)
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 12-20-2002, 09:41 AM
Thanks Bastiaan, I'll give that a try. Do I need to dither during this process?
Old 12-21-2002, 01:24 AM
Hey, it works!
Old 12-21-2002, 07:21 AM
neatguys neatguys is offline
yes dither on your master fader everytime you do a final bounce.
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit
Old 12-21-2002, 10:15 PM
Will do. Thanks
Sonar 3 jkung Pro Tools TDM Systems (Win) 1 12-16-2003 04:42 PM
Sonar 3 and PT le jkung 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-10-2003 09:20 PM
SONAR 3... Wow? Rock_Artist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 10-01-2003 07:53 AM
Sonar Raffles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-23-2002 01:38 AM
PT LE vs. SONAR ? CooknKPL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 20 07-05-2002 03:53 PM
