Protools 6.9 Update req Mediastation PT 1.6 update
When updating our protools TDM system I encoutered some problems I think are woth sharing with other protools users.
First of all, the Sync BOB needs to be at firmware v.1.1.1 (mine was at 1.1.0, so I had to flash it) When using a V10 for video, MediaStation PT 1.6 is required by Protools to operate with video and audio from Avid systems. This update however is never mentioned in the documentation of the 6.9 update download from the website of Digidesign. To make things worse, MediaStation 1.6 on it's turn requires Windows XP SP2 to install. So before you start here's what you need:
The last item is quite important as the installer of MediaStation overwrites some of the standard protools plug-ins like EQ II and Dynamics with incompatible versions and the Protools 6.9 installer does not include them anymore. The correct order in which to install these updates is still not clear to me, but don't do as I did. Probably the best order to install is:
After this all is installed start Protools and find out which plug-ins don't work and copy the original files back in to the plug-ins folder. Now all should work fine. Good luck in updating! |
Re: Protools 6.9 Update req Mediastation PT 1.6 update
Thanks for the post Marco.
As you mention, Media Station|PT 1.6 installs incorrect versions of 3 Digi plug-ins: EQII, Dynamics II, and Signal generator. If the correct install order is followed (Pro Tools after Media Station), Pro Tools will properly update these plug-ins to the correct versions. If Media Station was installed after Pro Tools, you will see the message, “The component Dynamics (or EQ or Signal Generator) expired on April 14, 2005. Please update your copy" when launching Pro Tools. For users who run into this, I'd recommend uninstalling the Digidesign Shared Plug-ins from Control Panel>Add/Remove programs, then reinstall the Digidesign Shared Plug-ins from the Pro Tools 6.9 install CD. With this method, you would not need to have a plug-ins folder on the system prior to installing. -Jordan |
HD Native cant Update Firmware after installing PT9.0.5 Update | Aditu | Pro Tools HDX & HD Native Systems (Win) | 72 | 11-27-2012 03:57 PM |
10.3 Update - Windows shutdown issue has returned. Update at your own risk. | crm0510 | Windows | 14 | 09-19-2012 01:50 PM |
10.5.6 update. Is it safe to apply the system update from 10.5.5? | SBCCMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-02-2009 02:27 AM |
Windows Update Vs Apples Software Update | sunburst79 | General Discussion | 2 | 07-14-2007 06:40 AM |
What is this Apple Update? Hard Disk Update...ver 1.0 | McMasters | Pro Tools TDM Systems (Mac) | 1 | 06-30-2003 05:56 PM |
