expert help: external efx connected digitally
Hi
I need some help to connect my outboard efx digitally to pro tools My setup: Pro tools mix 6.4.1 AD8000SE 888/24 888/24 The AD8000 acrt as master, the 888/24 interfaces are connected with superclock. SLAVE sync mode External efx: tc electronics M2000 connected with AES EBU to aes ebu ch 1-2 tc electronics M one connected spdif adapter to AES EBU into 888/24 to aes ebu ch 3-4 tc electronics D two connected spdif adapter to AES EBU into 888/24 to aes ebu ch 5-6 Lexicon PCM 80 connected spdif adapter to AES EBU into 888/24 to aes ebu ch 7-8 I use the neutrik AES EBU to spdif adapter M2000 connected to channel 1-2 and d two connected to channel 5-6 works great. I can also swap the connections for channel 5-6 to the lexicon and the m one and it works fine. BUT: ch 3-4 and 7-8 does not work. I can only monitor the output signal as I know the 888/24 always have the digital out active. But I get no sound into the 888/24 question: How can I get all the efx work at the same time with the 888?24? It is impossible bacause the 888/24 is in slave mode? Is the only solution to connect them to the AD8000 with a aes ebu card installed? Anyone have experience with using outboard digitally? What is the best solution having all my efx work at the same time? Hope someone can help |
Re: expert help: external efx connected digitally
there is NO such thing as this
you are confusing a AES to 75 ohm converter this is only to used if you are using coax cables for AES/EBU and is primarily used in longer runs of AES signal, adapting 150 ohm AES signals from a 75 ohm source i.e. A SDI/HDI DVR etc... IT DOES NOT change to format of a digital signal it ONLY changes the impedance
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Should that be 110 ohm AES signals
Andre Knecht Well fix it in the shrink-wrap. (Frank Zappa) . |
Yes sir you are correct 110Ω
yes I know it`s just a impedance converter , but the tc electronic efx and lexicon will work great with aes ebu using those adapters. But why does it work on ch 5-6 in pro tools but not on the other channels?
Is a USB connected external HD OK for PT and Mac? | Iron Shirt | Pro Tools 10 | 4 | 12-22-2011 02:10 PM |
Can't start up if I have external clock connected? | cprescott1972 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 06-05-2007 01:18 PM |
Outboard reverbs connected digitally above 48k? | crizdee | Pro Tools TDM Systems (Mac) | 13 | 02-16-2007 03:32 AM |
Digitally connecting external FX? | DougCurrie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-22-2003 03:58 PM |
Can external audio signals be digitally looped in and out of Pro Tools | RDJ | General Discussion | 2 | 04-11-2001 06:52 PM |
