Old 02-14-2005, 01:35 PM
1m1 1m1 is offline
Default Quickeys X3 compatibility with PT?
I've been holding off on updating to Quickeys X3, but I'm ready to do it now. I'd like to hear some reports of success or problems though before I make the move. TIA
Old 02-14-2005, 02:17 PM
Steve MacMillan Steve MacMillan is offline
Default Re: Quickeys X3 compatibility with PT?
I've been using without any problems. I would hate to be without it.
STeve
macmandigital.com
Old 02-14-2005, 03:21 PM
Mt.Everest Mt.Everest is offline
Just watch out using the 'option' key for any quick keys you make that deal with menu items that use warnings like "are you sure you want too...". Option force-bypasses these warnings in PT and most of MacOS functions.
MT
PT|HD4 Accel PCIx w Magma Chassis & 192 I/O
PT HD 9.0.5 - Mac Pro 8-Core 2.4Ghz Westmere 10.6.8
PT|HD 9.0.5 - MacMini Core-Duo, 10.6.8 - ProFire 2626
•••DON'T BELIEVE THE HYPE•••
•Use & Trust ø Cancellation!•
Old 02-15-2005, 11:43 PM
1m1 1m1 is offline
Thanks guys, for the info.
Old 07-27-2005, 03:15 AM
Jules Jules is offline
Hi Guys!
I am on a Mirror door G4
Mix + / OSX / Last revision of PT (for Mix +)
I am running a macro hot key "palette" (70 assignable keys) - it is a serial device, but I am feeding it via a USB - serial converter cable...
I have to stay with this Mad max "retro" rig - I've no budget to toss it out / upgrade..
The macro palette (a Gallery Mission Control, it houses a QWERTY keyboard, industrial size track ball, 70 key macro key pad and an unemployed Axis joystick panner - it all sits in an empty fader pack bucket in the middle of my 16 fader ProControl http://www.librarystudio.com/ click the studio tour book and press GO to have a look)
So Quick Keys...
Is it pretty easy to program?
This macro palette USED to be programmable via software called "Key Quencher" but that never made it up to OSX - and not being very tech minded in computer land myself, it was depressing to see my purchase semi defeat almost all the Mac tech's I have had through my studio... at various upgrade stages over the last 6 years, it lost some of it's functionality, bit by bit... never to return.....
Now, the recent move (finally) to OSX has really dumped it's functionality!... ALL it's keys need to be TOTALLY re programmed...
Help me get my 'idiot pad' back working again!
I am to old to learn keyboard shortcuts!!!
Any pitfalls / tip & tricks to getting it working?
Thanks in advance!
Jules
London, UK
Come hang with us here!
www.gearslutz.com
Old 07-27-2005, 04:36 AM
Andre Knecht Andre Knecht is offline
I love QuicKeys! And it’s getting better all the time.
When first switching to OSX, QK actually took a step back in terms of functionality. This was due in part to Apple not having implemented all the APIs that existed in OS9. However, with each new (major) version of OSX (Jaguar, Panther) QK has regained most, if not all of the lost ground. It’ll be interesting to see what new capabilities can be exploited by QK under Tiger.
I like QK’s new X3 interface. I find it more intuitive than ever before. I’m no QK expert, but I’m getting more out of it all the time. I am convinced that this is due in large measure to the application’s becoming more user-friendly.
I’ve recently discovered the beauty of multiple key strokes in creating subsets of commands that fit my way of thinking/working. For example, to launch any Apple-made application or utility, I now type my “Generic Launch Apple” shortcut, Control+i (which I chose because of the company’s penchant for using product names like ‘iTunes’, etc), and the follow that with another letter that I assigned to the specific apps. In the case of iTunes, that would be “t” for me. The beauty is that one can implement these multiple strokes so that QK patiently waits for the second key.
Shortcuts can be limited so as to only work while a specific app is open and in the foreground.
In PT, I implemented the “double keystroke” technique to follow the application’s menus as they appear on the menu bar. For example, “[modifier]+s” means I’m about to invoke something from the “Setups” menu. Typing “h” brings up the “Hardware Setup” window.
And so forth.
One great new feature, introduced with X3, is the ability to share shortcuts among multiple users, across a network. Program once, use everywhere. Pretty darn slick.
Did I mention I love QK?
I hope this helps.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 07-27-2005, 05:43 AM
Jsalam112 Jsalam112 is offline
Is QuickKeys 3 running under Tiger?
Old 07-27-2005, 07:41 AM
jimlongo's Avatar
jimlongo jimlongo is offline
I mostly use keystorkes and menu selections. I change some keystrokes I don't like to ones I do. I make menu selections that don't have built-in keystrokes. And best of all make sequences that have combinations of keystrokes and menus ( for instance you could have a keystroke that initiates many steps such as separate, tab, shift-tab, cut, option-tab, paste).
A tip for sequences in ProTools you may need to program pauses (0.1seconds usually works for me) if the sequence is too fast for your system/PTs to accomodate.
One thing I stay away from is screen clicks that rely on position on the screen . . . it only works if you never change the position of windows, which never works for me.
Yes
noise | jimlongo
Old 07-27-2005, 03:30 PM
Charles D. Ballard Charles D. Ballard is offline
One thing I miss from KeyQuencer is the ability to save multiple clipboards. I've just ordered Quickkeys (it should be here in a week or so). Does anyone know if they've added that ability yet?
-Charles D. Ballard, M.P.S.E.
"I bent my wookie"
Old 07-29-2005, 05:39 AM
Neveguy Neveguy is offline
I've been using quickeys for a few years now and love it's work
I'm having trouble getting the menu clicker to work eg i want to hit cntrl-opt-apple-s to initiate soundreplacer from the audiosuite menu.
Any hot tips?
Quickeys for OSX buckaroo Pro Tools TDM Systems (Mac) 6 10-28-2009 02:23 AM
Quickeys electrik noize Pro Tools TDM Systems (Mac) 4 09-03-2006 12:31 PM
Quickeys and 6.4 Jsalam112 Pro Tools TDM Systems (Mac) 9 05-26-2004 08:16 AM
Is anyone using Quickeys in OS X? AAR Pro Tools TDM Systems (Mac) 12 04-08-2004 04:02 PM
QuicKeys help Felix Pro Tools TDM Systems (Mac) 1 01-15-2004 08:27 PM
