Old 01-18-2010, 03:11 PM
Mano Mano is offline
Default Copy and Paste pluginsettings feature request
Just recently i switched over from ProControl32 to D-Command40.
There is one knob/ softkey i really miss, or i fail to find it.
Its copy and paste plugin parameters. On the ProControl this one was placed under the automation write to start/end buttons.
This one stroke just copied all plugin settings from a targeted track. Next you could just as easy hit the paste button to paste the data to any targeted track.
I used this alot on the Procontrol and it was very handy in quickly setting up lots of eq and dynamics in several recordingchannels.
Now i have to select, target, hit Shift command C and then pffffffff getting tired of selecting and shift command V over and over again.
Could this please be re-implemented in a next systemsoftware-release.
Or better : make it possible to program any makro you choose on to userkeys...that can't be too difficult. Just let the console learn your favorite command-string that's not listed in any preprogrammed softkey-page.
Like : select unused audio regions> Shift Command U
delete selected regions > shift Command B
and then option click delete.
Well...this last request is beyond the scope of this post ... I just like to see the buttons to copy and paste plugin-settings back on the controlsurface.
P.S. above i didn't write copySP plugin automation data.
Old 01-18-2010, 04:36 PM
trombino trombino is offline
Default Re: Copy and Paste pluginsettings feature request
I'm a new icon owner myself, but i think you can achieve what you want by holding command+shift while pressing the select key on the insert you want to copy from, then pressing bmp of the insert you want to paste to (while continuing to hold command+shift).
Mark
Old 01-19-2010, 06:38 AM
Soundtrack Soundtrack is offline
This shortcut works great on a channel by channel base.
Would be great if you could also make direct a copy of the plugin settings from the center section in the same way, so you could paste the settings per channel after tweaking the parameters in the center section.
Grz,
Louis
PS Mark, how do you like your Blue Dcontrol....
Old 01-19-2010, 09:32 AM
I LOVE IT!!!!
I think I had it for only a couple of days before I had my "how did I ever manage without this" moment. :)
Mark
Old 01-19-2010, 12:29 PM
Lol... i have a blue 40 fader d-command since september, due to busy business i had not been able to really work with it since last week.
Thanks for the hint !
i'll try the comm shift select comm shift bmp thingy :)
still would really be great if digidesign just makes programmable macro softkey's for this,,,,
Old 01-19-2010, 04:37 PM
tomlowd tomlowd is offline
if you combine command+shift+selct to copy and paste parameters (check the manual, there's a good explanation of how to do it) with "do to Sel" and "link Track and edit selection" you can do some really fast stuff
like select a bunch of tracks with your mouse, then paste your eq setting to all of them. also, to copy from the central part of the d-control, you just have to copy from the insert page of the focus strip, click you mouse on the tracks you want to copy to, hit "do to sel" then "paste it onto one of the tracks.....
Old 01-19-2010, 08:43 PM
Brandonx1 Brandonx1 is offline
How exactly do you do this on the pro control? I've searched the manual for this and can't find it. Sorry about hi jacking your thread.
Best,
Brandon
Old 01-20-2010, 09:53 AM
Pete Gates Pete Gates is offline
You can't, he must mean Control 24.
Pete
Old 04-07-2010, 04:23 PM
Best,
Brandon
Sorry i dindt mention i had an editpack
Copy... Paste... Paste... Paste...? accession 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-18-2022 04:18 PM
copy and paste EVERYTHING aldersyde Pro Tools 10 1 06-10-2012 09:23 AM
Feature Request: Auto Save Copy When Opening Session flymax Pro Tools TDM Systems (Mac) 0 01-27-2011 07:25 AM
Copy works paste doesnt paste??? SoMedia Pro Tools M-Powered (Win) 12 01-04-2011 01:19 PM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 12:46 AM
