Is Pro Tools 2018 EVER going to be supported on a current Version of High Sierra?
Apple is up to 10.13.6 and Pro Tools 2018.7 still only works with 10.13.3. That leaves a whole lot of new Macs unable to run Pro Tools.
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
Re: Is Pro Tools 2018 EVER going to be supported on a current Version of High Sierra?
Don't know but it works fine for me...
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
No Prob here on MacBook Pro or Trashcan. MBP with Vanilla, & Trashcan with Ultimate .7...
2018.7 runs fine for me on my iMac Pro.
Especially after changing the color profile in display settings. I have no GUI lag now.
Pro Tools 2018.7 iMac Pro 10core 32gb ram 1tb internal ssd 1Tb OWC Thunderbolt-3 Libraries 1Tb USB3.1 PT projects, Software, and Samples 4Tb USB3 G-Raid TimeMachine drive 1Tb USB3 OWC mini raid mirror archive drive Promise TD-300 Thunderbolt-3 dock Apple TB-3 to TB-2 adapter to Focusrite Clarette 8preMaudio Keystation 88es controller Native Instruments Maschine Studio gen1 Akg k240 anniversary edition 2 KRK Rokit 8 Gen2 Monitors Alesis M1 active Gen1 1 KRK 10s Sub |
Is anyone having success with 10.13.6 running HDX and recording with low buffers?
THAT is my understanding of what the issues are with OS’s over 10.13.3. Even with 2018.7 and 10.13.3, I have to run at least one buffer size up than I did with PT 12 and prior. I do a lot of orchestral OD sessions with 16+ tracks in record at once to a fairly large number of reference stems. 2018.x has been problematic compared to 12 and prior. I can’t afford to have it get any worse. Looking forward to Avid getting this fixed.
I see you're running 2018.7 HD version. What's the difference between the regular pro tools and HD version? Do you think there would be difference in it running the regular 2018.7 on High Sierra 10.13.6?
Which OS version are you running? So you're having zero problems running your pro tools 2018.7? What year is your iMac Pro? Did you upgrade from your OS from Yosemite? Thanks for the info.
Greetings!
Could anyone possibly verify whether or not you are able to export an AAF file running PT 2018.7 or later on OS 10.13.6? I have PT 2018.10 installed on OS 10.13.6 and PT just gets stuck when trying to export an AAF file. Previously I was running PT 12.5.1 on OS 10.13.6 and I had the same problem. My post link regarding this problem for reference http://duc.avid.com/showthread.php?p...43#post2505043 These are the settings I used And this is the screen where PT just gets stuck after I hit OK on the previous image If you could verify this problem for me that would be GREAT!!! Thanks!!
System Details Media Composer 2020.6 Pro Tools 2019.6 Mac Pro 2013, MacOS Mojave 10.14.6 • 2.7GHz 12-core with 30MB of L3 cache • 64GB (4x16GB) of 1866MHz DDR3 ECC • 1TB PCIe-based flash storage • Dual AMD FirePro D700 GPUs with 6GB of GDDR5 VRAM |
I have nothing but trouble with ProTools, i9 Processor, 32GbRAM and OS 10.13.6. CPU overloads no matter the buffer. With no plugins, and only 1 track recording, highest buffer I cannot record more than 20 minutes without errors. It is a total disaster. Meanwhile Logic Pro X, Tracks Live, Audacity, Reaper and Audition ALL work fine with this machine and the exact same set-up. So I cannot use ProTool to record anymore. Cannot trust it for alive performance. So Sad. They are well over a YEAR out of date.
Question: Sierra or High Sierra for PTHD 2018.3? | johnnyv | Pro Tools 2018 | 25 | 03-18-2018 08:30 PM |
Pro Tools 2018.1.0 does not recognize AVID MBOX Pro under High Sierra 10.3.3 ... | 2arabigo | Pro Tools 2018 | 10 | 03-02-2018 02:07 PM |
PT HD 2018.1 HDX and High Sierra on Mac Pro Westmere 3,33 | drums77 | Pro Tools HDX & HD Native Systems (Mac) | 5 | 02-24-2018 12:16 PM |
High Sierra 10.13.3 PT 2018.1? | off the wall | macOS | 10 | 02-16-2018 08:25 AM |
macOS High Sierra 10.13 not yet supported | Avid | Technical Alerts | 0 | 09-25-2017 11:29 AM |
