Concerning virtual instrument playback
Hi all,
I've been looking in the DUC for an answer to this and so far have come up with nothing. I'm using PT 12.8.3 on a Windows 7 64bit system with 16GB memory. My projects are about a 70/30 ratio of audio tracks and virtual instrument tracks. I don't really ever use any external MIDI instruments, it's all originating from within Pro Tools. My trouble is this - When I'm playing back my session and hit STOP, the VIs continue playing out their last note and eventually stop when the note duration would have finished anyway. Likewise, often when I hit PLAY, the VIs will take a few seconds to catch up and play a lot of notes quickly to catch up. This has cost me a lot of time when I'm doing work that requires a lot of tight edits and playing back repeatedly. BEFORE you say it, I'm well aware that I can commit the VIs to audio in 12.8.3. However, my preference is to leave them as VIs until the very final mix, in case a MIDI parameter is what really needs tweaking. So maybe there's a nice fix that can cut off the MIDI notes instantly when I hit STOP? Something I've overlooked? Thanks much! Audio Bob |
Re: Concerning virtual instrument playback
What VI?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
amagras,
It's the same story no matter what VI. My current session has a string pad from XPand2, a couple of DB-33 tracks and a couple of Waves Grand Rhapsody piano tracks. Other sessions with different VIs behave the same way. |
Are you working with a small Sample Rate? This has happened to me when I have a session with to many VIs and only happens with some of them. Having to many edits on screen has caused my sessions to slow down, for example after applying Beat Detective to a lot of drum tracks, usually group g all the clips makes it better and consolidate works better.
Just throwing a few ideas out
That's a good suggestion. I do in fact have extremely edit-heavy sessions. Consolidating the tracks might help. I'll give it a try.
Please report back if it works.
I finally had time to try this suggestion. Unfortunately, consolidating all the edit-heavy tracks had no effect.
Why not temporarily freeze/commit the VI's you are not presently editing? It will slow you down a little but may cause less aggro in the long run.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
I have had similar, but not in a long time. Trashing prefs and database files might be worth a shot. What are you using to enter/record midi data? Assuming a keyboard of some kind, is Midi Studio setup to route midi back to the keyboard? Just wondering if there is some weird midi loop
Ive had similare problems in previous versions of PT in the past but not on all VIs. Like Dave suggested try disconnecting any synths or midi keyboards to se if it has any effect. I would also suggest maby trying a newer version of PT. Last resort is to freeze/bounce tracks.
Boom Virtual Instrument was "Unauthorized" during virtual instruments download | Singer1212 | General Discussion | 1 | 12-29-2014 11:10 AM |
virtual instrument playback issues | riden1080 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-02-2011 06:56 PM |
Virtual Instrument help! | madgt621 | Virtual Instruments | 2 | 04-06-2010 05:57 AM |
Multiple Virtual Instrument Playback while recording | eklektos | Virtual Instruments | 4 | 11-08-2008 04:13 PM |
Lag when using virtual instrument... | onebigtrip | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-22-2008 10:47 AM |
