digi 002r crackles and disconnects
macBook (Not pro)
OS X 10.4.10 2GHz Intel Core 2 duo PT 7.1.1 with cs update Digi 002R connected firewire non-oxford usb2 drive has been working fine Everything's going GREAT, sometimes for days, then a rush of campfire crackling and I've lost my connection with the 002r. I trash the midi4744784??/ prefs, the coreMnager pref (when it's in there) the PT plist and the DAE prefs. I also jiggle the NEW power harness and turn everything off, reseat the fire wire connections, and re-start. Sometime she comes back quickly, sometimes she don't. suggestions? thanks. -J |
Re: digi 002r crackles and disconnects
Probably you are suffering from a faulty power-supply (design fault which Digi will fix for free). Just look in the post for 'power harness faillure' and you'll find out more. I ha d the exact same thing for a couple of months, which ended with a complete breakdown (only the mute-button lit and no way of connecting; a dead 002r that is).
So don't wait too long to get it fixed! |
This was already done. It has a NEW power harness, but the problem persists.
bump
I replaced the power harness in my Digi002 but still losing communication also(no crackle sound though).
I'm on my third harness so I'm thinking it may possibly be the firewire bridge : http://www.digidesign.com/index.cfm?...0&itemid=22425
24" imac-2.33G core 2 duo 2 GB memory OSX 10.5.6 Glyph GT050Q 500G Glyph GT050Q 1TB(Backup) PT 8.0 Digi002 |
For everyone:
The harness was replaced, I have both lights inside, so it's not the firewire bridge, and finally I upgraded fro 7.1.1 to 7.3 - then 7.3.1 - then did the cs4 update, trashed my preferences and the verdict is.........it connected, detected a firewire reset and then disconnected. Anyone? |
Have you tried a new firewire cable??
..dog
PT 9 Control 24 003 Rack Mac Pro 2.66 Quad Adam A7 Waves Gold, VSeries Pultec Bundle URS, McDSP |
I have this exact same Problem you are experiencing, only difference is I use a Macbook Pro and PT 7.3.1cs4. The problem is now at the point where I cant run any sessions including some I made months ago and used without issues. My Pro Tools setup is completely useless right now. I have had the Power Harness replaced already, maybe the new one is bad as well. I replaced the Firewire cable and still problems. Signs are pointing to a hardware problem because both CPU Monitors (Apple and Pro Tools) read less than 40% system usage when my errors are coming. I have also tried EVERYTHING listed on this site from changing settings to trashing prefs to disc permissions and nothing will solve this problem. I got a response from Digi's tech support with suggestions for fix's I have already tried several times. I will be contacting their repair center tomorrow morning about sending it in for testing.
Macbook Pro 2.16 2GB Ram 10.4.9, Digi002r, PT LE 7.3.1cs4, Yamaha HS80M Monitors, Native Instruments Komplete 4 |
MC Mix disconnects after 20 sec | lbow | Artist Series | 2 | 06-09-2011 01:13 AM |
optical crackles on 002R | warpusall | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-23-2010 07:46 PM |
002r disconnects? | barznbeats1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 07-18-2005 10:13 PM |
002r disconnects all the time !!! | Bossi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 09-27-2004 12:13 PM |
THE DIGI ZONE- Tonights episode- "FARM CRACKLES | Natural Sound | Pro Tools TDM Systems (Mac) | 2 | 10-18-1999 10:13 PM |
