Old 03-04-2019, 05:27 PM
JakeBirch JakeBirch is offline
Default Issues Connecting iPad to Eucontrol Windows 10
I have previously been able to use the PT | Control App without issue. Recently, though, it seems to have (mostly) stopped connecting to Eucontrol. Every once in a while Eucontrol will see the ipad, but there's no rhyme or reason that I can discern. So far, no solution I've found in the guide or on this forum has fixed the issue.
I'm using this with an artist mix to control Cubase, and the artist mix shows up, and using the steinberg app, I'm able to control cubase from the ipad, but Eucontrol does not recognize the ipad. So, I know I'm on the same network and the ipad is able to connect to the computer somehow for Cubase, but not Eucon.
Really, I'm just trying to be able to group things on the artist mix that I can easily recall. So even if there's another app besides PT | Control that can do this, that would be a viable solution for me. I'm also considering buying a lightning to ethernet adapter and a router to create a wired connection for the ipad, but before I throw money at this problem, I'd love some suggestions for things to try.
Old 03-06-2019, 07:28 PM
Default Re: Issues Connecting iPad to Eucontrol Windows 10
Maybe your wifi router needs updating? For me, a cheap N wifi router was very unreliable. Once I switched to a dual-band router, connection has been almost 100% solid
Old 03-08-2019, 01:54 PM
Hey thanks for the idea. I'll look into this. I doubt it's the cause though because I have a relatively new and middle-of-the-road router (not cheap). Funny enough, a day or so after posting this, it seems to have just as inexplicably started working reliably again. No idea why it stopped or why it started up again. Go figure.
EuControl v3.7.0/ Pro Tools | Control on iPad Pro doesn't work... Smithtrax Avid S1, S3, Dock and Control App 47 03-10-2018 07:48 PM
Eucontrol 3.7 with iPad Pro 12.9 2017 bobo mark Avid S1, S3, Dock and Control App 0 02-16-2018 05:48 PM
S3 connecting to Eucontrol but not PT Macsearcher Avid S1, S3, Dock and Control App 6 09-19-2017 11:16 AM
EuControl/Workstation 3.3 & Pro Tools | Control iPad app now available! Kyle Splittgerber Avid S1, S3, Dock and Control App 0 08-06-2015 02:59 PM
