Panning center to left to right to center
Hi, newb question here, and it might sound a little strange since I don't really know how to explain it. I was just wondering how you would pan one track from the center to the left to the center to the right back to the center. Is it a plug-in? Double track? Here's an example:
http://www.soundclick.com/bands/song...songID=3020817 at 00:52 |
Re: Panning center to left to right to center
Why wouldn't you just "pan" it using the "pan" function?
SoundPunk | Pro Tools Tips & Tricks |
HI
1) as already said, just use the standard pan function and if you enable automation then this will be remembered as a dynamic move. 2) or map it in the pan drop down in the track arm section in the left of the edit window 3) or as lots of engineers might prefer and Ive done this myself many times, if its a swift move youre after, you can copy the audio to 2 mono tracks and if youve a desk, use the faders under a finger to effect a pan merely by adjusting the volume of each leg. Personally I find mixing on the mix window a very poor option being used to a console. Peter |
Better yet, select PAN to show on the track(in the edit window), use the grabber tool to put break points and drag the line up(for left) and down(for right).
5.1 Mix Narrator Center channel Dialogue Centre or phantom Center? | kd_special | Post - Surround - Video | 5 | 03-02-2011 02:53 AM |
Automatic volume going left, right, center | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-04-2009 07:58 PM |
alt st going to Left/center when alt pressed | vga | ICON & C|24 | 1 | 05-02-2009 12:19 AM |
panning all going to center?!? why? | chal7ds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-14-2006 10:34 PM |
Panning in PT defaults to Center | Mark Reis | Post - Surround - Video | 2 | 05-14-2003 09:44 AM |
