Old 12-06-2018, 12:59 PM
Emi's Avatar
Emi Emi is offline
Default Plugin load balance between cores
I just realised using multimono plugins instead of multichannel for stereo instances balances the load better between cores.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 12-06-2018, 01:01 PM
s.d. finley s.d. finley is offline
Default Re: Plugin load balance between cores
interesting, good to know!
sdf
www.sugarhillstudios713.com
Old 12-06-2018, 02:49 PM
priorytools priorytools is offline
Really?
That’s a fantastic discovery.
Gonna check that top tip out tomorrow.
Noice.
Thanks.
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 12-06-2018, 04:18 PM
crizdee's Avatar
crizdee crizdee is offline
Cores or virtual cores?
Some computers have say 12 cores but 24 virtual cores! I don’t know what’s changed in recent versions of PT but a mixer channel/ track could only access one core (but this could be 2 virtual cores stemming off the same core)
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-06-2018, 04:51 PM
What I suspect is going on here is what Chris refers to above, the core affinity/binding of a signal chain. When you add a stereo plugin I suspect the normal core affinity of processing a signal chain binds both sides of a stereo track to run on the same core, with multi-mono the both sides are independent as far as processing goes and their processing can be on different cores, or to a greater extent on different cores.
Remember that hyperthreading is the work of the devil. It can help but it's far from being just another core. The other "core" only gets to use parts of the actual hardware if workload if its twin is leaving them idle. I expect Pro Tools just throws thread workload at each pair of hyperthreaded cores (and that keeps instructions and data local on the shared L2 cache). Wether you see equal distribution across each hyperthreaded core or not might not mean anything, but you sure should not expect to see both pairs of hyperthreaded cores near 100% utilization.
Old 12-06-2018, 11:00 PM
Emi's Avatar
Emi Emi is offline
Originally Posted by crizdee View Post
Chris
Cores. I have hyperthreading deseabled with great results in stability.
Old 12-06-2018, 11:16 PM
Emi's Avatar
Emi Emi is offline
Looks like...
12.6 Every Plugin Was Disabled On Load? risey Pro Tools 12 4 10-12-2016 05:18 PM
Why does PT 12.4 HD not spread CPU load evenly on cores? Justin1524 Pro Tools 12 4 02-23-2016 03:32 PM
Cores and cpu load bradp Pro Tools HDX & HD Native Systems (Mac) 3 01-17-2012 04:07 AM
Mac Octo 2.26: Almost no difference between 2 Cores and 8 Cores Hive Guy macOS 8 05-10-2011 11:05 PM
Plugin presets don't load into Plugin's-Why? Stratman Pro Tools TDM Systems (Mac) 0 01-20-2001 10:30 PM
