Old 11-05-2018, 01:18 PM
jpellizzi jpellizzi is offline
Default HD Native Thunderbolt - Headphone Jack Left Side only with 5.1 output?
So I just updated my edit room to 5.1 with the HD Omni interface, and it's all fantastic.... except that when I set my Main Output to 5.1 in the Hardware settings of the Omni, the HD Native Thunderbolt heaphone jack only outputs the L side or channel 1. It seems to think that Channel 2 is the center channel, even though I'm using the L R C LFE Ls Rs channel order in the Hardware tab.
The Omni headphone jack correctly outputs 1-2 to the headphones, and I thought the thunderbolt box was just supposed to mirror that? I've tried switching around the channel order, but the only way to get sound on the right ear is to pan something to the C channel in 5.1.
Anyone else have this problem or a potential solution? Otherwise I'll have to change my hardware monitoring settings every time I do a stereo session vs a 5.1 session, or just stick to the Omni headphone jack.
Thanks!
Old 11-07-2018, 09:09 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: HD Native Thunderbolt - Headphone Jack Left Side only with 5.1 output?
The box should mirror outputs 1-2 of your first interface
Janne
Old 11-10-2018, 11:30 AM
s.d. finley s.d. finley is offline
which would more that likely be Left channel and Center channel. You need a stereo fold down to outs 1-2
sdf
www.sugarhillstudios713.com
Old 11-11-2018, 04:31 AM
paulo m's Avatar
paulo m paulo m is offline
I wonder how the behaviour would be if using a MTRX, since 1/2 outs can be AES, analogue, MADI, Dante. Will it be the analogue outs that get replicated? Or indeed 1/2 regardless of protocol?
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
Old 11-11-2018, 02:14 PM
BScout BScout is offline
Since you assign the routing inside DADman, it will be whatever is assigned to 1/2 on the first ProTools primary connection (minidigilink.) Pro Tools only sees the connection (minidigilink) it has no idea what the box behind it is doing. The MTRX is routing a signal source to a destination. The endpoint to Pro Tools is always the same (as the destination) -- it's not changing any kind of "protocol"
If you think of the mini-digilink cable as any other audio cable, it'll be what's going down 1/2.
Old 11-12-2018, 04:09 AM
paulo m's Avatar
OK, it makes sense. Thanks for the explanation.
Regards,
Paulo M
Mac System Sound through HD Native Thunderbolt Interface Headphone Jack Captain Audio Pro Tools HDX & HD Native Systems (Mac) 8 12-06-2018 10:23 AM
output to headphone jack on imac rjyoung1 macOS 4 12-01-2017 04:32 AM
Not getting output from headphone jack on Thunderbolt Bridge Cartoonmoon Pro Tools HDX & HD Native Systems (Mac) 1 09-03-2014 06:43 AM
Sound in left side of Headphone jasont Windows 4 12-24-2013 11:02 AM
No headphone jack output - Meters showing output Hotcrazyfruit Eleven Rack 6 05-06-2012 12:09 PM
