NI Studio Drummer glitches?
I'm having the pops and cracks with my audio when using Studio Drummer.
I've done quite a bit of research on this, but I still need some clarification on how to make this work. I'm going to keep this as short and specific as I can. My setup: Digi 002R Mac Pro Early 2008 2 x 3 GHz Quad-Core Xeon (8 cores total) 6 GB RAM Mountain Lion 10.8.2 *Live and Studio Drummer apps are installed on the system drive, the S.D. library is stored on an different drive reserved for all of my audio. *Alesis USB drum kit with TriggerIO Ableton Live 8.3.4 (NOT the 64-bit Beta that's out) NI Studio Drummer and Live are installed on the system drive 1) Should I move my SD library back to the system drive? I assumed it would be better on a secondary audio drive, to free up work for the system drive, but I'm not sure if this is a bad move with respect to performance. 2) When I run Activity Monitor, it doesn't indicate that I'm running low on Memory. Would I benefit from more RAM, even though this is the case? 3) I have the ability to support multi-core processing within the Live settings, as well as the Kontakt AU plugin settings, with Kontakt running as an AU plugin. What combination of multi-core processing should I select to get maximum performance? Turn it on in Live, but disable it in Kontakt/SD? 4) My Mac supports 64-bit processing. Should I upgrade to the Live 64-bit beta? 5) In Live prefs, what should I set the CPU Usage Simulator percentage to? 6) I'm assuming I should start with a low buffer size and high sample rate, check for glitches/pops, then gradually increase these settings. Based on my setup, what should I start out with, and how should I go about doing this? I've tried disabling the effects in SD and using only the lite versions of the kits, but it's still not doing much to improve performance. I know a lot of these questions have been touched on in forum posts for NI and Live, but I'm still at a loss. Thanks in advance for any feedback! |
How to Record Kontakt 5 Studio Drummer | Cayce | macOS | 25 | 12-04-2017 04:52 PM |
Studio Drummer? SD2? Another suggestion? | jobey | Virtual Instruments | 10 | 01-19-2014 10:17 AM |
Studio Drummer Issues with Protools 10 | shameusf | Pro Tools 10 | 3 | 09-04-2013 05:10 PM |
CPU problem with NI Studio Drummer - how about SSD4? | nstu | The Drum Room | 4 | 07-15-2012 01:14 AM |
New Track (Rough) with Studio Drummer | 60Strat | Eleven Rack | 3 | 10-07-2011 06:35 PM |
