#261
Re: Are we not due an update??!!
^^^^ This ^^^^
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X |
#262
Perhaps Peter Gabriel can save Avid like he did for SSL. :)
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
#263
Its all a rear guard action now. Retreat wink wink to the higher paying ground they can defend
www.kfaudio.ca |
#264
But even if you print your tracks, if Pro Tools is no longer able to open due to not being compatible with your OS, how do you recover your tracks? Just curious because what I know about printing doesn't solve this....or does it?
Pro Tools 2023.3 Ultimate, Omni, I/O, Pre, HDX, iMac Pro, OS 12.6.5 https://soundcloud.com/jason-kalman |
#265
#266
cheers john
#267
... as long as they all start from zero and therefore don't need a session file
#268
yes, that is the Case !! thx Janne !!
#269
But any previous mixing is lost. Obviously you can open the track files, but without the mixing everything you have done is lost. Sometimes I want to do a few tweaks of a mix for video or other purposes, or need a redone mix without lead vocal, etc. Those things require the ability to open a session. Yes, one can print the FX, but that defeats the purpose.
#270
#1- print tracks RAW, no Automation .. so as you say No Mix Elements #2-print tracks WITH Automatioin and Print All FX .. in this way, your Mix would return to you .. sans, your Master Bus Processing, if you did any .. now, this would probably sufice for archive for most people .. having to open sessions and do little tweaks .. obviously not .. keep an older system intact and fire it up once in awhile .. making sure the entire system Boot Drives and All are Backed up 2-3 times !! fun stuff !!! john
Sierra 10.10.6 - To COMBO update - or App Store Update ? | Seafoam_Green | macOS | 6 | 01-07-2024 05:19 AM |
Update Module Firmware message after 3.7 update | WildHoney | Avid S4/S6 | 1 | 10-21-2017 11:28 AM |
HD Native cant Update Firmware after installing PT9.0.5 Update | Aditu | Pro Tools HDX & HD Native Systems (Win) | 72 | 11-27-2012 03:57 PM |
10.3 Update - Windows shutdown issue has returned. Update at your own risk. | crm0510 | Windows | 14 | 09-19-2012 01:50 PM |
10.5.6 update. Is it safe to apply the system update from 10.5.5? | SBCCMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-02-2009 02:27 AM |
