Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 01-08-2021, 04:20 PM
Sonopolis Sonopolis is offline
Default Re: Can't add audio to track
I vaguely remember I once had a similar issue on MacOS. Is it really any file? Any file type? Can you drag to the clip list and then to a track? Can you drag from the PT file browser? Can a third party app like Soundly spot to PT?
Old 01-09-2021, 07:02 AM
SpencerBoyd SpencerBoyd is offline
Originally Posted by TOM@METRO View Post
This may or may not be contributing, but Pro Tools requires at least 16GB RAM. (32GB or more recommended)
https://avid.secure.force.com/pkb/ar...m-Requirements
Good call, I didn't realize PT required 16 GB. It looks like I need to upgrade.
What I meant was, are you getting just a place holder... And yes you can. I have a session where for some reason the tracks were accidentally not getting recorded to the session audio files folder and was sent somewhere else.
When I opened the session, I could see the tracks, even had all my edits and cross overs, but no visual representation of audio.
All I'm asking is it possible the audio file isn't the location you think it's in?
Yes, just the placeholder and no waveform. In this case I'm certain of file location. I've tried a bunch of files I can play with Windows Media Player but nothing in PT.
W10 20H2 is not supported. Could your Windows been updated lately?
I updated not too long ago but PT has worked since I updated. I didn't realize it 20H2 wasn't supported, I guess updating was a mistake.
I've tried from the clip list too, unfortunately there was no difference.
I guess the bottom line, for now, is to upgrade my RAM to at least 16 GB. Hopefully there's an update for PT to support 20H2.
Thank you, everyone!
Old 01-09-2021, 07:53 PM
I realize that the OP is on W10 20H2, so the 16GB RAM minimum may be an issue. The same requirement is also stated for Mac OS X, but I am able to run Protools on a spare machine with only 8GB RAM, including dragging and dropping wav or mp3 files into tracks. Although getting more RAM is highly recommended, I'm not 100% convinced that the limited RAM is the sole reason for this issue.
I know it is a pain, but I would try a clean install of the OS (a compatible version of Windows if possible) on a separate drive and then install Protools to test.
Obsidian Dragon
Model Name: MacBook Pro
Model Identifier: MacBookPro14,3
Processor Name: Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 16 GB
MacOS 11.2.3 running Protools 2021.3
Old 01-10-2021, 04:12 PM
Sure enough! I reloaded Windows 10 20H2 (I didn't have any option to go back) and everything is back to normal. Perhaps when creative cloud was uninstalled it wiped out a dependency that PT uses??
Thanks for the help!
Old 01-10-2021, 04:35 PM
Glad we got it sorted.
Obsidian Dragon
L3 Cache: 8 MB
Memory: 16 GB
  #16
Old 01-11-2021, 07:21 AM
TOM@METRO's Avatar
Great news!
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2020.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
External synthesizer > midi track > aux track > audio track typhy macOS 1 01-17-2015 08:17 AM
No audio being sent through bus from instrument track when bussed to audio track. dope5050 Virtual Instruments 14 05-26-2013 01:46 PM
Copy Audio Track Automation to Midi track controller (Mod Wheel) cybercampbell macOS 3 05-11-2013 10:18 AM
Unable to Record (digitize) a Regular Midi Track to an Audio Track JuicyMusic macOS 9 02-27-2013 08:52 AM
Problem bussing audio from one track to another audio track harryk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-04-2010 12:15 PM
