Old 05-24-2000, 11:52 AM
wcody wcody is offline
Default Can\'t Audition Crossfades, DAE Error -2804
When I select an area in preparation of a crossfade, hit command-F to bring up the fade dialogue box and click the audition icon to preview the fade, I am immediately presented with:
"DAE Error -2804."
After dismissing the DAE error dialogue box, the crossfade waveforms are constructed, and I'm presented with another error box stating:
"Audition of 24bit audio is not supported for the current HW setup."
When I dismiss this second error dialogue box, and accept the fade, it is successfully applied to the playlist.
I'm running a 24 bit session. I've tried running with and without the Digidesign Output Driver extension. The problem persists regardless of the crossfade selection length. This particular error is not listed in the Answerbase.
I would like to actually AUDITION the fade prior to accepting it, as stated in the manual, page 243.
Any clues?
Cody Cabaña Productions
Old 05-24-2000, 05:38 PM
DigiTechSupt's Avatar
Default Re: Can\'t Audition Crossfades, DAE Error -2804
The "Audition of 24bit is not supported for the current HW setup" alert message is due to the fact that Pro Tools LE uses Sound Manager (which only supports 16 bit) to preview fades.
I am currently investigating the DAE -2804 error. It is possible you do not have all of the necessarcy system extensions (namely the Open Transport extensions) installed and/or enabled in your active Extension set. Open the Extensions Manager Control Panel. From the selected set pop-up menu, select “OS 8.x or 9.x base” click on “Duplicate Set" at the bottom of the window and name the set whatever you like. Scroll down and enable the DigiSystem INIT, Digidesign DSP Manager, Digidesign Output drivers and the Open Music System Extension. Make sure that you have the Shared Library Manager and/or the Shared Library Manager PPC installed and then restart the computer.
Brent
Avid Audio Tech Support
Support FAQ
Old 05-24-2000, 08:57 PM
coaster coaster is offline
i also get this error whenever i attempt an audition of 24bit fades.
uh,
why not just create an audition of a 16 bit fade to send to sound manager? we want to hear the fade quality, not neccesarily the sound quality.
sorry brent, but this seems like a no-brainer for digi to implement.
www.mp3.com/xtac
for the faint of goth
Old 05-25-2000, 01:48 PM
auditioning fades in a 16bit session works flawless (asssuming proper setup).
the solution is fairly clear:
in a 24bit session, while aditioning fades, digidesign needs to write a subroutine that would allow a 16bit version of the fade to be outputed to sound manager.
the only workaround i have found is to compile the fade, listen, and undo or go on with the fade.
i don't think this is to much to ask....
www.mp3.com/xtac
Old 05-26-2000, 12:18 AM
Brent -
I tried your suggested extension procedure to the letter, and both DAE error and "not supported" error persist identically. I also tried selecting both "built-in" and "Digidesign" sond outputs, still with identical failures.
In your reply you state:
The "Audition of 24bit is not supported for the current HW setup" alert message is due to the fact that Pro Tools LE uses Sound Manager (which only supports 16 bit) to preview fades."
Are you saying that LE simply doesn't support fades preview? The manual clearly states otherwise.
Thanks!
Old 05-31-2000, 12:19 AM
OK, I misunderstood the "Audition of 24bit audio is not supported for the current HW setup" message. Now I understand, thanks to coaster.
To expand on the remaining "DAE Error -2804," it occurs in an identical fashion even with 16-bit sessions. I cannot audition the crossfade at all.
My config is an upclocked beige G3 at 300MHz, 256MB RAM, O/S 9.0.4, running all the latest Digi updates.
Brent, any progress?
Audition Crossfades using SP/DIF out? SumOdRsn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-14-2006 07:16 PM
DAE error 2804 Radu Goldis Pro Tools TDM Systems (Mac) 2 02-01-2003 10:44 AM
DAE error -2804 JRogers Pro Tools TDM Systems (Mac) 3 10-16-2000 05:48 AM
DAE error -2804 ? Dongsoo, Lee Pro Tools TDM Systems (Mac) 1 08-16-2000 07:28 AM
DAE Error 2804 slickrick Pro Tools TDM Systems (Mac) 3 06-01-2000 10:42 AM
