Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 06-18-2011, 07:03 AM
Riquier Riquier is offline
Default "you need to have a valid audition path in I/O setups to audition" - HELP !
Hi there !
All was fine until I started getting the following message "you need to have a valid audition path in I/O setups to audition" whenever I try to audition/preview an audio file on the workproject window. This happened out of the blue. The worse thing is that my I/O setup hasn't been changed at all... any ideas ?
I'm running PT M powered 8.0.5 on 2.0Ghz Intel Dual Core 2 iMac. My interface is a profire 2626.
cheers !
Old 06-20-2011, 01:52 AM
raystag raystag is offline
Default Re: "you need to have a valid audition path in I/O setups to audition" - HELP !
You'll find it in the I/O, just select your outputs.....
Old 06-20-2011, 06:46 AM
Yeah, you might go to the IO setup section and hit the DEFAULT button to see if that solves the issue. Sometimes, opening a session that was started on another system can wreak havoc with your IO setup. Once you do have it as you like, I would choose Export and save it as your setup. That way, if another session overwrites it, you can delete all paths and import your setup(I say delete paths because, for some reason, even though OT is supposed to delete duplicate paths, it usually doesn't)
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 01-15-2013, 09:14 AM
jameswilletts jameswilletts is offline
Question Re: "you need to have a valid audition path in I/O setups to audition" - HELP !
Hey, folks.
I was googling for answers this morning as to why my I/O setup that I've exported does not include the Audition Path information. I've tried holding option (which I know you have to do when importing, but not so much when exporting; still worth a shot), and even re-saving. Alas, the Audition Path still defaults to "no output".
What gives? Anybody have any clues?
Thanks for reading. Kind of an old thread, but still relevant.
'Twill be a grand day when I can open a session and not have to visit the I/O setup.
- James
James Willetts
http://www.jameswilletts.com
Old 05-17-2013, 02:15 PM
Ray Lyon Ray Lyon is offline
Go to I/O set up and select the output tab. On the bottom section of the display choose "Audition Paths" pop-up to select your main mix out (usually 1 - 2) and you should be good to go. Be sure to save it as a setup so you can get back to it later and import if needed.
Old 04-29-2014, 02:34 PM
hmac hmac is offline
Ray, thanks so much for your post. Just saved me a lot of f'ing around. Worked like a charm.
iMac 27" (mid 2017) i7 Quad core, 4.2Ghz, 16GB RAM, High Sierra, 1 TB internal SSD + external SSD's for recording & samples. Digi 003 Rack, Pro Tools 2018, Kontakt 5.8, Edirol PCR-800 controller, Mackie Control Universal, Mackie HR824's
http://soundcloud.com/thinman-studios
Valid audition path ? twistedinsane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-01-2012 03:52 PM
Audition Path jamiecer Pro Tools TDM Systems (Mac) 2 06-16-2008 09:14 PM
Audition Path Felix Rost Pro Tools TDM Systems (Mac) 0 03-14-2007 05:53 AM
Audition path miha78 Pro Tools TDM Systems (Mac) 0 06-06-2006 01:20 AM
Audition Path in PT7 innesireinar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-31-2005 10:47 AM
