Old 09-09-2010, 05:55 PM
odominguez odominguez is offline
Default Recording C24 Listen Mic
Hey guys,
I was wondering if any of you know of a good way to record the output of the C24 listen mic. This things seems to have compressor that sounds extremely interesting, and I would love to have the ability to record it to Pro Tools. Is this possible?
Old 09-09-2010, 10:08 PM
Fullsound Recording Fullsound Recording is offline
Default Re: Recording C24 Listen Mic
To slate, simply route the mic from the surface to a input of your choice.
www.fullsoundrecording.com
Seattle Wa
I voted at www.deardigi.com
Old 09-09-2010, 10:16 PM
Yeah, but how? This microphone input has independent control on the surface itself. I see no way of getting its output routed anywhere. As far as I know it is hard wired to the speaker output. This is what I would like someone here to help me find...
Old 09-10-2010, 07:40 AM
SpongeBob SpongeBob is offline
The output of the C24 talkback mic is available on channel 5 of the Cue Outputs connector on the back of the unit. (see page 112 of the user guide)
I route mine to a track in PT to insert into the headphone mix.
Note: A patch panel is ideal for routing the the cue outputs and control room outputs from the C24.
You can do the same ... just take the output of the talkback mic from channel 5 of the Cue Outputs connector and bring it into PT as if it were a room mic.
Say, didn't Phil Collins do that on one of his recordings .... possibly In The Air Tonight?
Bob
PT10 HD Native (10.2.0), 96 I/Os, C24, Mac Pro (10.6.8 / 16GB)
Old 07-25-2013, 09:26 AM
SBMusicAndPost SBMusicAndPost is offline
i know this is old but the question originally posted does not pertain to the talk back mic. The c24 and the icon's have a separate "listen" mic. This is designed to be a small discrete mic placed in the booth or live room as a room mic for communicating with performers. The benefit of this mic is being able to hear people talking in the room without having to open pro tools or have any other mics set up. my listen mic is permanently hidden in a corner tucked into the fabric of the wall. You simply turn it on and off when you want to hear it. I am not sure if there is a patch point for it on the db25 or if it just goes to the mains.
Old 07-26-2013, 04:08 AM
paulo m's Avatar
paulo m paulo m is offline
He did, but was using an SSL listen mic circuitry, not a C24
Regards,
Paulo M
Old 07-24-2016, 10:38 AM
Brahamnesik Brahamnesik is offline
Hello, did you guys find a solution to record the listenback mic?
Old 07-24-2016, 11:56 AM
YYR123's Avatar
YYR123 YYR123 is offline
I'm sure it sounds the same as an SSL...
Daniel
I want to listen watch and listen to tutorials and have PT coming through my monitors phatbeatstudio Pro Tools HDX & HD Native Systems (Mac) 3 10-15-2012 07:48 PM
Listen if you like Pete Evick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-12-2003 11:00 AM
new recording.. take a listen. Kleekoh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-26-2003 04:23 PM
new recording... take a listen. Kleekoh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2003 11:29 AM
I can't listen the SINGER while playback witout recording him eddybertrand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 03-13-2002 12:12 AM
