Old 08-03-2010, 05:31 PM
harryk harryk is offline
Default Problem bussing audio from one track to another audio track
I have a mono bass track with digi compressor and sans amp plugins. When I buss the audio from this track to another to record the effects, the new audio track is 30 samples behind the original track. I have to nudge it back. Does this seem right if there is supposedly no delay for the plugins. It shows zero delay when I cntrl-click the audio volume indicator.
PT 12, Gigabyte GA-X79-UD3 ATX LGA2011 MB,Intel Core i7-3930 3.2GHz 6-Core Processor,Asus NVIDIA GeForce GT 640 2GB GDDR3 PCI-e Video Card, Patriot Viper 3 Low Profile Blue 32GB (4x8GB),Cooler Master Hyper 212 Evo CPU Cooler, Rosewill Stallion Series RD700 700W Power Supply,Western Digital Caviar Black Internal system/session/samples,Windows 7 Professional 64-bit,Mbox2
Old 08-03-2010, 06:36 PM
ondruspat ondruspat is offline
Default Re: Problem bussing audio from one track to another audio track
Maybe test to see where the problem is coming from. Remove the plugs from the track and see if it still tracks through the bus with the lag. If there's no lag on the first run add plugs one by one testing each.
"Sometimes having limits keeps you sane"- Albee1952
Old 08-03-2010, 07:57 PM
Top Jimmy's Avatar
This happens because in your I/O setup, this particular bus path is setup for mono and stereo use. If you want to see it print correctly, delete the stereo bus pair, leaving the mono ones.
What most people don't realize is that Pro Tools LE does have routing compensation, and there are some instances where problems can arise because of it. If you want an example, make sure bus paths are setup for both mono and stereo. Create a bunch of mono aux tracks. Set the track outputs and inputs such that the path will go through them all, and assign the buses consecutively. Route some audio through this path and you'll hear problems because the routing compensation can't work correctly for the mono paths when they are also stereo paired. Pro Tools LE can't handle it when one side of the pair is feeding the other side. Solving this issue is as simple as deleting the stereo bus paths and leaving only mono ones for the buses you want to use mono.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6.
Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac)
Pro Tools 2020.12, Mbox3 (Win)
Old 08-03-2010, 09:28 PM
albee1952 albee1952 is online now
Check your buffer setting. If its at 1024, try it again at 128(or 64) and see how much offset you have. You could also just save the settings for those plugins and process the audio in place with the AudioSuite version(just recall the same preset and process).
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 08-04-2010, 10:30 AM
Top Jimmy, thanks for the suggestion but even setting it up as suggest, separate bus paths not stereo paired, I'm still getting a delay of about 30 to 40 samples. This is with the H/W Buffer size set to 64.
Old 08-04-2010, 11:09 AM
albee, tried it with H/W Buffer set to 64 with the same results. I guess it's either audiosuite it or nudge it. Maybe, it's a problem with sans amp.
Old 08-04-2010, 11:18 AM
mykhal c's Avatar
mykhal c mykhal c is offline
did you try another plug with zero latency to see if you got the same result?
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 08-04-2010, 11:30 AM
Yes, just tried it with Cmprs/LD3 with no latency. So it's sansamp then. It shows no delay when inserted, however.
Old 08-04-2010, 11:41 AM
spkguitar's Avatar
Wasn't sansamp one of the plugins that reports latency incorrectly?
Check out this old, old post.
Sansamp is on the list as reporting 0, but actually generating a delay of 28. (if I'm reading it right)
Old 08-04-2010, 11:42 AM
mykhal c's Avatar
yeah pretty sure PTLE relies on the plugin mfgrs to supply the latency numbers. no ADC so i sure wouldn't expect PTLE to be supplyin' it
Kontakt 5 with LASS on a midi track bussing to an audio track Ambient Dreamer Windows 0 08-19-2012 06:22 AM
bussing instrument tracks to audio track Kalfari General Discussion 5 03-04-2011 04:34 PM
No signal when bussing to an audio track. lalalandguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-02-2009 07:35 PM
bussing to audio track for recording not working bowserlm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-15-2005 01:18 PM
Recording thru Aux(bussing to regular Audio track) tapani 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-04-2005 01:27 PM
