Old 03-04-2010, 11:44 AM
JNS JNS is offline
Default Crane Song Phoenix question
Hi. I checked the compatibility docs and found version 2.10.5 of Phoenix to be OK with PT 8.0.3. So I download (from Digi's site) what is listed as 2.10.53. After I installed it and checked the version using "Get Info" it showed version 2.4.4x24. I contacted Digi TS and they tried to help, but couldn't. Said it probably was the right version, but that the version info was never changed. That wasn't good enough for me. I then called Crane Song who also couldn't tell me what was going on or latest version of Phoenix. They are supposed to call back.
Anyway, can someone here who's running Phoenix OK on PT 8 on an Inel Mac please tell me which version of Phoenix shows up when using "Get Info" to check it. I'm trying to figure out what I really have and if it's OK.
Thanks,
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Old 03-04-2010, 05:02 PM
JNS JNS is offline
Default Re: Crane Song Phoenix question
ttt
Old 03-04-2010, 06:51 PM
Dusty Angel Dusty Angel is offline
http://www.cranesong.net/download.html
Old 03-04-2010, 09:38 PM
JNS JNS is offline
Thanks for the help with the Crane Song download page. I couldn't find that anywhere on their site.
Jeff
Old 03-04-2010, 10:08 PM
Sean Russell Sean Russell is offline
I love this plug. Did you get it working?
... but does it help the chorus?
Old 03-04-2010, 10:16 PM
JNS JNS is offline
Well, I haven't had a chance to download from the page Dusty Angel steered me to. I don't know what version I really have, but it seemed to work fine. I haven't seen version 2.4.4x24 mentioned anywhere else but in my "Get Info", but that's what I supposedly have. I'll check with Crane Song again tomorrow just out of curiosity if nothing else.
Jeff
Old 03-05-2010, 12:30 AM
Mark Dann Mark Dann is offline
Thanks,
Jeff
I have called Cranesong on at least two different occasions, and they could never tell me what the latest version number was. It seems that the latest version is not at all recent, and that is is called by several different numbers, depending on where you look (installer, get info, Cranesong site, Digi compatibility list, etc.). It's really depressing that even Cranesong can't tell. If ou figure it out, please let me know!
Old 03-05-2010, 06:58 AM
25ghosts 25ghosts is offline
Thanks,
Jeff
If you downloaded the latest greatest and it works - what does it matter what the finder info says ?
FYI - My version states the same as yours
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10
Old 03-05-2010, 07:13 AM
JNS JNS is offline
Well, first I'd like to know that it really is the latest and second, sometimes these things appear to work and down the line one finds out that some quirk in it causes problems in certain circumstances and a newer version was later issued to correct this. But, thanks for letting me know your number is the same. Based on yours and Mark Dann's responses I have a feeling that the numbering system is just all screwed up.
Jeff
Old 03-05-2010, 08:00 AM
Well, first I'd like to know that it really is the latest and second, sometimes these things appear to work and down the line one finds out that some quirk in it causes problems in certain circumstances and a newer version was later issued to correct this. But, thanks for letting me know your number is the same. Based on yours and Mark Dann's responses I have a feeling that the numbering system is just all screwed up. It is sad, though, that the manufacturer can't even figure out what it is.
Jeff
My SpectraFoo is version 4.2 or something like that but the Finder states it is 4.x000
So dont rely on the Finder or the vendor to actually get the numbers right.
ESPECIALLY in the case of Metric Halo. If you wanna know about bugs get Metric Halo software. It's filled with creepy bugs
FS:Crane Song Phoenix and Phoenix II Digitaliz Buy & Sell 1 08-22-2013 12:30 PM
Crane Song Phoenix TDM v1 ILOK ASSET MIKEROPHONICS Buy & Sell 8 02-08-2013 02:13 AM
Crane Song Phoenix AAX Stereo? yamahadrums AAX Plug-ins 3 10-24-2012 07:55 PM
Crane Song Phoenix not compatible with PT 7.3? rascalseven Pro Tools TDM Systems (Mac) 2 02-26-2007 02:30 PM
CRANE SONG Phoenix ukoomrann Pro Tools TDM Systems (Mac) 3 01-14-2006 03:12 AM
