Massive Pack 8 or UAD-2?
I am in the midst of upgrading my studio with a complete PT HD2 system in addition to my existing Logic setup. The plan is to use the PT system for tracking and mixing what I compose in Logic.
So... I wonder how capable a HD2 system really is, and would like your opinion as to what I should get - the Massive Pack 8 TDM or stick to the UAD-2 I already have in my current system and transfer that to the PT system, then buy a couple of additional plugins if neccessary. I guess my question is... if I will be running my projects at 88khz (or maybe 176 actually, if it REALLY sounds better) and have about 16-20 tracks of audio going on in an average project, how much will I be able to do with the TDM plugins from Massive Pack and how do they compare to UAD? I already use and love UAD plugins, but I don't know what will give me the most plugin power - the TDM system or the UAD-2. Of course there's the advantage with the TDM plugins that if I run out of DSP I can use RTAS versions instead. On the other hand, I can get a UAD-2 quad card for the price of the Massive Pack 8 and that one has a lot of DSP power. Any recommendations? |
Re: Massive Pack 8 or UAD-2?
There will certainly be different points of view here, including my own----but my take is this. The UAD2 card is an amazing product offering a great deal of processing to power its own plugins, which are good----VERY good. The quality of plugin code is only possible because of the available and dedicated DSP that is made available to the plugins and its under-lying design similar to how Pro Tools HD works. But the thing to remember is that while this is a DSP-accelerated card similar to an HD card, it's still meant to operate in a native environment where sample buffers and third-party drivers are utilized. What I mean is---the TDM environment is designed, thinks, works, lives, operates, functions, etc as ONE system. The UAD2 card is an "add-on" that brings in some incredible plugins, but you do lose things such as REAL-TIME MONITORING, DELAY COMPENSATION (There is a way around this, but again it's just not the same), LIMITED RESOURCES for your TDM plugins, etc. By the time you buy the QUAD card with all of the plugins, you've spent more money than the current MassivePack Pro deal.
Is it worthwhile to add a UAD2 card? In my opinion, sure---why not! HOWEVER is it the right option to add? Well, that will really depend upon your needs and desires. Personally I'm considering one myself, but that is only because I already have an HD3 Accel. |
BradLyons,
Thanks for your point of view. I just wonder how many plugins I'll be able to run on a HD2 system. As far as I can tell there are no plugin instance charts available like there is for the UAD-2 so it's very hard for me to know what I'll be getting. And I need to buy the Massive Pack 8 before I get my HD system together, to get it at its current price. I know all plugins use different amount of resources, and at different sample rates etc. so it's hard do say anything general about. |
OP: There's is no definitive answer really! TDM plugin count really depends on which plugs you use? I love UAD plugs and i Love many of the TDM plugs, so i can only recommend both Chris
Chris,
The ADC is taken place by another application that works alongside of ProTools, but it's not exactly integrated into the TDM engine is my point. I'm not saying it's a bad idea or NOT to do it----but personally I prefer to take advantage of the TDM processing first. In a perfect world, BOTH would make sense. |
Hi Brad, I think you are confusing with the LE ADC app ATA from mellomuse! UAD works just like any other plugin in HD systems, no need for ATA. Chris
You might be right! Sounds like a reason for me to purchase one, so I can edumuhcate muhself on this again
Sony EQ http://www.sonnoxplugins.com/pub/plu...ts/EQ-Spec.htm Sony Dynamics http://www.sonnoxplugins.com/pub/plu...s/Dyn-Spec.htm URS http://www.ursplugins.com/instances.html McDSP http://www.mcdsp.com/index.php?optio...=48&Itemid=128 Altiverb http://www.audioease.com/Pages/Altiv..._Pro_Tools.pdf Can't find much info on Waves. The Altiverb instance counts are a tad disappointing!
Dave Marsden UK |
I too am very interested in this as well. However, I am going to buy another Accel card first to make my system an HD3. I was thinking I might want to get a Magma chassis and put my HD cards into it. I want to also pick up a UAD-2 card next year when I buy my new Mac Pro.
I tested the SSL Duende which uses a VST wrapped format. Although the plug-ins sound great it took away resources from the TDM engine. As I had to turn on delay compensation long. Is this the same case with the UAD-2??
___________________________________________ Mac G5 Dual 2.0 / 5 GB RAM / HD 2 Accel OSX 10.5.8 / PT HD 8.0.1cs2 Apple Powerbook 1.33GHZ/ M-Box 2 OSX 10.5.8/PT LE 7.4.2 |
With UAD2 the delay induced is exactly the same as your buffer setting! buffer set to 256? delay for UAD is 256!! (a few uad plugs will have a slightly higher delay, due to being up-sampled for higher resolution processing! this would make them about 20-40 samples on top) If you want to record with a UAD plugin inserted, there is a "live tracking mode" which processes the signal almost immediately. but there's a limit to how many plugs can be in this state at once!! fine for single over-dubs etc. don't know how many tracks can be in LTM but it would depend on your buffer size and processor power etc. HD6 in magma chassis and UAD-2 duo in computer working great. Chris
Anyone with massive pack 5 and 8 on 10.6.5??? | audioluche | Pro Tools TDM Systems (Mac) | 8 | 03-17-2012 07:01 PM |
Massive Pack 8 | Evil Jack | Pro Tools TDM Systems (Mac) | 1 | 10-12-2009 10:36 PM |
Massive Pack? | TimNielsen | Pro Tools TDM Systems (Mac) | 3 | 06-04-2005 08:40 PM |
Massive Pack 3 for XP? | cachemira | Pro Tools TDM Systems (Win) | 0 | 11-26-2004 05:14 AM |
How is the Massive Pack? | quark | Pro Tools TDM Systems (Mac) | 3 | 10-05-2004 01:43 PM |
