Old 10-25-2005, 06:26 PM
Stig Eliassen's Avatar
Default Premiere export - Pro Tools import
Hi.
I'm about to start my first post production for a short movie, and basically....I haven't got a clue. This gig just landed on me. So let me ask about some basics:
- Will all the audio regions in Premiere contain timeline information so that they can be spotted correctly in PT?
- How do I import and spot all the audio regions from Premiere? Do I need any additional software to get started?
Thanks in advance.
Old 10-26-2005, 02:04 AM
gerax gerax is offline
Default Re: Premiere export - Pro Tools import
The best thing you can do is export an OMF file and open that in Pro Tools (BTW, which version and hardware are you using?).
OMF files contain all of the audio files and crossfades used in the video editing already spotted at their exact position, with basic volume maps and levels; so you have an head start and can just work from there, smoothing the mixing, adding sounds, panning and doing your thing.
Obviously this ability in Pro Tools comes at a price: to be able to open OMF you need Digitranslator, which is sold separately or as part of DV Toolkit which also adds some other capabilities and post useful features (Timecode rulers and a pair of handy plug ins). You can find them in the Digistore for download.
If you don't (can't) want to purchase the Digitranslator then it can be done by rendering all of the audio tracks from the same start (usually the first frame if the picture), then lining them up in PT and cutting them back to the needed size; an alternative could be to use time stamped .BWF files (if Premiere has this ability) and Spot load them in pro Tools; a bit time consuming, but doable.
Hope this helps.
L.G.
Old 10-26-2005, 06:18 AM
Hi.
Thanks for replying. PT software version and hardware is listed in my profile. I will check with the video editor what possibilities Premiere has. I will also read up on Digitranslator and DV Toolkit.
Thanks again.
Old 10-26-2005, 06:25 AM
Just because you have digitranslator it doesn´t mean the OMF from Premiere will open. Premiere is kinda famous for bugs and not working transfers. You should test a small sequence first and see what gets translated.
Some "exotic" apps don´t translate volumes, clip-names and other details...
frank.
PTHDn 2021.3 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron
Old 10-26-2005, 01:38 PM
If that is the case I'm probably better off importing audio that's been consolidated from start to finish.
Thanks.
Old 10-26-2005, 02:25 PM
minister's Avatar
minister minister is offline
i'm with frank... i have never gotten an OMF from premier that translated either. MAC or PC version. consolidated track audio is best.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 10-26-2005, 08:01 PM
rantanplan rantanplan is offline
Someone told me that the only way to get a usable OMF out of Premiere is to remove all tracks of a project but the one to export. Then you export a EDL file with the EDL Manager. So you have to make one project for each audio track you want to export, which only contains that ONE audio track.... Then you import the EDL in Avid and reallocate the source media files. After you have done this for every EDL you export the OMF from AVID.
I hope u understand what I mean
Good luck!
Old 10-26-2005, 11:08 PM
berk berk is offline
Hi
You can try this product
the catch is audio keyframes become gain automation in OMF (clip volume, not track volume or audio gain)
it's around $500
cheers
berk
Old 10-27-2005, 09:04 AM
Hi.
The video editor uses some lighter version than Premiere Pro so I'm probably stuck with "full-lenght" audio tracks for now.
Thanks, guys.
HTML code is On
OMF import from Premiere cs6 into PT 10 problem bebeuriarte Windows 3 09-28-2013 03:06 PM
OMF import error from Premiere Pro 6 PT11 HD IMLaudio Pro Tools 11 0 06-25-2013 09:14 AM
PRO TOOLS EXPORT TO CUBASE IMPORT TIMING ISSUE Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 34 07-25-2007 05:22 AM
Import audio from Premiere Pro 2.0 Flaf Post - Surround - Video 0 01-06-2007 11:31 AM
AAF Import from Premiere FlorianE Post - Surround - Video 6 07-28-2006 06:24 AM
