Old 11-27-2020, 02:17 PM
LelioP LelioP is offline
Default Artist Mix not connecting
My Artist Mix refuses to show up on EuControl.
What I tried so far:
- Reinstall Eucontrol to same version
- Reinstall to a previous version
- Update to latest version
- Use DHCP
- Use static IP address on same field (169.254.235.xx) and same subnet mask 255.255.0.0
- Use different cat cable: currently cat5, tried cat7
Eucontrol version is 2020.11.0.187; on my 2008 MacBook Pro the Artist Mix was recognised by the system (rectangles) as soon I turned it on, version 18.3.0.244.
Any way to check Artist Mix Firmware?
Any help would be greatly appreciated.
Avid Artist Mix, Mac Mini 2018 i7 6-core 3,2 GHz, MacOS Catalina 10.15.7, Logic Pro X 10.6.0
Old 11-28-2020, 09:24 AM
Default Re: Artist Mix not connecting
Also:
- set firewall to off
- Checked EuControl in Accessibility
Old 11-29-2020, 09:20 AM
EddieJones's Avatar
Those IP addresses are not static they are self-assigned. Did you change them in the Mix or is the Mix set to DHCP? Make sure the Mix and the Ethernet adapter are both set to DHCP. Its not a firmware issue.
Old 11-29-2020, 04:14 PM
Thanks for your reply.
I am connecting my Artist Mix directly to the Mac Mini via Ethernet cable.
I tried setting DHCP on both Artist Mix and Network Prefs; also tried setting a static IP to no avail.
Setting everything on DHCP, Network Prefs shows a self assigned IP address that uses same (correct) fields and (correct) Subnet Mask as on the Artist Mix.
Do I have to power cycle everything after setting everything to DHCP?
Old 11-29-2020, 08:09 PM
EddieJones's Avatar
You always have to power cycle when changing network settings (for most equipment not just EUCON) Have you tried a different cable? Try disabling any other network adapters including WiFi.
Old 12-01-2020, 05:50 PM
I am connecting direct to the computer via Ethernet cable.
Tried a different cable - nothing (no rectangles, just AVID logos)
Tried (again) setting both Artist and Network to DHCP - nothing
Tried (again) setting a static IP, following the guide on AVID support page - nothing
Always power cycling computer, Artist Mix and EuCon.
Seems to me the unit is not receiving the correct IP from Ethernet, pushing page up and down together to check the IP address shows different fields tha the Network Prefs. (eg Artist Mix: 169.254.064.053; Network Prefs, set to DHCP: 169.254.107.7. Subnet mask is the same)
Is there some rep in Italy I can talk to?
Old 12-01-2020, 06:29 PM
EddieJones's Avatar
Those 2 IP addresses are OK and should work. Have you tried to uninstall (using the installer) and also checked the remove all prefs option.
Old 12-02-2020, 12:36 PM
Tried uninstalling with remove prefs checked and reinstalled EuCon 2020.11.0.187, rebooted, nothing.
On my old 2008 MacBook Pro running ElCapitan 10.11.6 with EuCon 18.0.3.144 the Artist Mix gets rectangles as soon as I start Eucon.
It gets recognised as McMix in the EuControl settings window.
Old 12-02-2020, 01:21 PM
EddieJones's Avatar
Can you check the Mac Prefs for Accessibility and make sure MCClient and EuControl are enabled in there.
Old 12-02-2020, 02:17 PM
Checked - They are both enabled.
One of my two Artist mix suddenly not connecting colliderman Artist Series 1 09-14-2020 07:40 AM
Artist Mix not connecting to Pro Tools 12/2018 tslleach Artist Series 6 09-20-2018 10:18 AM
ProTools Not Connecting to Artist Mix MicMan Artist Series 2 01-02-2018 03:37 PM
Problems since connecting two artist surfaces Mirek Artist Series 2 11-04-2016 10:33 PM
Artist Mix & Control suddenly not connecting michael@sounddesign&mix Artist Series 1 09-15-2016 06:22 AM
