Old 03-03-2004, 02:59 PM
gregory dean gregory dean is offline
Default Using recorded kick to trigger samples....help!
Hello there,
Just wondering if anyone out there can answer this question. I want to layer another kick drum into an already existing recorded piece. Should I used the recorded kick to trigger a sample from my drum machine? How is that done? Or is there a better way to do this? I'm not using a sampler, just a boss drum machine(dr770). Thanks much.
greg dean
Old 03-03-2004, 03:23 PM
Chris Cavell Chris Cavell is offline
Default Re: Using recorded kick to trigger samples....help!
The easiest way (and probably the only feesible way due to time and equipment constraints) is to sample the sounds you want to use into PT and then use digidesign's soundreplacer plugin.
Cavell Studios
Old 03-03-2004, 11:15 PM
Calvin Calvin is offline
Well, what part of the kick sound do you want to modify. If you are just wanting to add a deeper low sound to it you can record a 50-60 hz sine wave over the entire length of the song, then use the digi gate Audio Suite pluggin to gate the sine wave, but use the original kick sound as the side chain for it. It's pretty easy to do and you can really add some low tones to the kick sound, depending on how quickly you have the gate acting you can even get a little bit of snap in there too.
Calvin
Old 03-04-2004, 04:18 AM
kalle74 kalle74 is offline
Hello there,
greg dean
If your drum machine has trigger inputs, route the signal from the recorded kick to it via an analog output ( recorded kick should be gated well to avoid miss-triggering ), and record the triggered sample on another track. After recording, align the transients and check the phases. I do this all the time with a Alesis DM5. Soundreplacer is also nice...
How do I trigger a kick in Transfuser from a MIDI file in PT? baslotto Virtual Instruments 1 11-11-2013 04:40 PM
Kick Drum Trigger rorygirl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 03-21-2011 09:16 PM
Kick Track to Trigger TEMPO TAP teacherman Tips & Tricks 11 07-12-2010 12:53 PM
How to trigger samples? Gwyn ap Harri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 11-29-2004 09:25 AM
OT:Patching a MIDI trigger on a drum kick j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-06-2003 04:31 AM
