Old 04-29-2003, 09:11 PM
ghostman420 ghostman420 is offline
Default I need good extension settings
I already checked the answerbase and found a few helpful things on this subject. But I would really like a list from top to bottom of good extenion settings for running PT 5.2. I use an external firewire drive. I think the rest of my setup is listed below. I'm sure somebody has taken the time to get a good set of extension settings. I just wanna get the most out of my system. Already have it set to 256 colors (that's plenty for me). I also have 200 MB of RAM allocated to both PT and the DAE. Any help here would be greatly apppreciated. Thanx guys and gals. [img]images/icons/cool.gif[/img]
eMac
700 Mhz
640 RAM
M-box
PT 5.2
Old 04-30-2003, 02:53 AM
Philthy Philthy is offline
Default Re: I need good extension settings
It would be tough to cut & paste from one computer to another... there are variables. Computers are fickle to begin with.
Your best bet- start with the base extension set and turn on anything else you need. Sort the extensions by on/off column, then go through all the offs and turn on what you know you need- OMS, DAE, etc. Usually if something else needs to be on, the computer will let you know when you try to do something related.
Phil Mann
Silk City Music Factory - CT Recording Studio
mp3 extension change default settings maxon Pro Tools TDM Systems (Mac) 7 10-03-2011 12:28 PM
Are Corsair XMP Settings Good for PT? EarBud 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-04-2011 09:59 AM
Good settings for vocals on Focusrite Trackmaster pro? Illmatic919 Virtual Instruments 0 01-07-2010 05:12 PM
Good gate, compressor, and limiter settings BiazedUnfidelz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-28-2005 07:24 PM
Good Limiter/Compression Settings for Radio Commercials r steele Tips & Tricks 7 12-22-2002 02:48 PM
