Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Dock
Old 11-09-2018, 08:23 PM
rbeggs rbeggs is offline
Default iPad Pro, Pro Tools Dock, ethernet connectivity issue?
Page two of the Pro Tools | Dock guide describes using the Apple Lightning to USB 3 Camera Adapter + USB 2 Ethernet adapter to establish a hard wired connection between the ipad and the host computer.
This configuration does not work with my model MQDT2LL/A 10 1/2" iPad Pro. The iPad recognizes the camera adapter but does not show connection to ethernet. What's odd is that both my iPhone X and a smaller iPad, model MP21F2LL/A, both connect to ethernet through the same connection that does not work with the iPad Pro. Both iPads are recent models running the latest IOS.
Apple phone support had no answer and gave up, telling me to factory reset the iPad or go to the "Genius Bar". Well, that went as expected, only worse. I was told that the configuration is not supported by Apple. I demonstrated how that dongle set lit up my iPhone and the other iPad with an Ethernet port before her very eyes. She simply said, "That's not supposed to happen, it's not supported". Good luck.
Avid tech support was diligent and worked hard but gave up and said they'd kick it upstairs and get back to me.
This does not appear to be a Pro Tools problem and the manual says it works. I admit I haven't tried the factory reset yet.
Has anybody else experienced this issue? What am I missing?
Thanks,
Richard Beggs
Edit/Delete Message Reply With Quote Multi-Quote This Message Quick reply to this message
Old 11-10-2018, 07:50 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Default Re: iPad Pro, Pro Tools Dock, ethernet connectivity issue?
I'm not sure of your adapter issue unfortunately but if your wifi network is setup good the Control App should be Ok on that in the meantime.
Old 05-06-2019, 05:03 PM
gersonlazoq gersonlazoq is offline
Bassist | Producer | Recording & Mixing Engineer | Arranger | Composer
Mac Pro Late 2013 | 2.7GHz 12-Core Intel Xeon E5-2697v2 Processor | 64GB of 1866MHz DDR3 ECC | 1TB PCIe-based SSD | Dual AMD FirePro D700 GPUs with 6GB of GDDR5 VRAM each
macOS Mojave 10.14.5
UAD Apollo x8p
UAD Satellite Octo Thunderbolt
UAD Satellite Quad Thunderbolt
Focal Alpha 65
Furman M-8x2 Power Conditioner
Avid S3 Control Surface
Pro tools Ultimate 2019.5
EUCON 19.5.1
Pro Tools Control 19.5
iPad Pro Late 2018 | 12.9-inch | Wi‑Fi | 64GB
Ken Smith Bass 6 Elite
Aguilar Tone Hammer 500
Epifani T112
Jazz Composition/Performance/Music Production & Engineering candidate at
Berklee College of Music
Old 05-06-2019, 05:04 PM
Hi Eddie,
What’s your knowledge about connecting the new iPad Pro 2018 directly through the USB-C cord? I tried it this morning in my iMac Pro and it was recognized perfectly on the Eucon app without wifi connection, later I tried it on my Mac Pro (trashcan) through the Thunderbolt 3 ports of my UAD Apollo x8p but Eucon didn’t recognize it unless I turned on WiFi. Currently on the latest versions of Eucon, PT Control and lates PT Ultimate.
Any help?
Best,
UAD Apollo x8p
Focal Alpha 65
EUCON 19.5.1
Epifani T112
Old 05-08-2019, 06:36 AM
EddieJones's Avatar
It has to be on the same network...going through the Appollo won't work.
New ipad pro-Dock Jazzbass56 Pro Tools | Dock 1 11-01-2018 09:14 AM
iPad Pro 10.5 and PT Dock roland@alpharecords Pro Tools | Dock 18 02-21-2018 09:22 PM
Best iPad for the dock? Brandonx1 Pro Tools | Dock 7 11-05-2016 04:51 AM
which Ipad for the Dock... TrackerLe Pro Tools | Dock 6 09-05-2016 03:45 AM
