Re: Will elastic audio ever get fixed?
ok i just don't get it.. I have been reading this topic scratching my head...
The biggest thing I am going to MISS about PT going to Cubase IS EA. I use it every single day, in warp view, transient marker view, all the different styles, i auto quantize, groove quantize, manually move audio to snap to beat, none of the algorithms give me any issues... In cubase i need to open a separate window, i can't do it on the main page and it's not as intuitive. Yeah, i don't get it.. not only have i never had a crash with elastic audio, all the algorithms including x form sound great and i have never had any weird behaviour. Not trying to discount the OP and others, but i don't get it.. What can I do to try and reproduce it exactly? there is something I am missing here. PS the only x form issue i have is that when using the x form plugin in audiosuite, none of the algorithm choices make any difference to result, like transient sensitivity etc. it's completely broken in that regard but this has nothing to do with EA.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
Logic's new Smart Tempo takes audio stretching and quantizing to new levels. I just tried it on some very complex material (solo piano, among other things), and it was near flawless. Tried the same test in PT and got the usual warbly audio loaded with artifacts. Maybe someday Avid will again get competitive in this area, but so many of us have raised our voices to Avid on this for the last five years, and it doesn't seem like this is something they care about.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
I use if for short noted transient material as well. Both for bass and guitar. Don't forget strip silence might also sometimes be a good alternative. EA I haven't used for years. Could never get good results with it. |
PC workstation: Windows 10 Pro i7 12700K RTX 2080ti 64GB DDR5 5200mhz RAM 2 Samsung 980 Pro 1TB SSDs Samsung 850 Pro 1TB SSD LG 34" Ultra-Widescreen monitor Pro Tools 12.4 A loaf of bread A stick of butter A lot of rye whiskey |
#16
The problem I have most often with EA is that after moving one warp marker, I have to consolidate the clip to get any of the other warp markers to work. If I don't consolidate, the other markers will move, but the underlying audio doesn't. The problem is random, it seems somewhat algo specific, and perhaps even somewhat specific to certain material (probably due to the amount of transients being analyzed). I also see occasional wonky behaviour where the audio waveforms change in appearance and sound once EA is removed from a track, or the smearing of transients that other people have reported, or the random situation where the clip just won't process - it just stays greyed out until I consolidate, and then it magically processes the audio. I wonder if Avid didn't maybe open a can of worms (with EA) that they weren't really prepared to have to deal with, as coding this kind of thing can't be easy (comparatively), and they don't seem to be devoting resources to fixing it, unless they are and just haven't mentioned it at all. Ever.
#17
I don't do live multitracked drums by the way but have watched beat detective tutorials on those. I use EA on vocals, guitars, and loops when i want to change the timing. Sorry about that and not noticing the multi part. My apologies.
#18
I am trying it right now in 10.4.1 the avid mono algo is terrible true.. rhythm is great (just an auto slicer really) and the same as logic's rhythm mode (quality wise). Just be thankful you are not using cubase timestretch for drums.. it's literally unusable, you have to hand slice and crossfade everything, it's the only way.
#19
Try quantizing an acoustic piano track in PT, and then try in Logic with Smart Tempo on, difference is stunning. PT sounds like a wow and flutter fest, on every setting you can think off. I wish it weren't true.
#20
Sounds fine. Of course in x form mode only though.. poly is ok for preview... I tabbed to transient also as a second test and moved to beats manually.. all worked fine.. Logic is a real POS if ever there was one.. I mean what's more important? Fundamental mixing that works? I think so. Logic is the world's only DAW that plays ghost VI notes in empty space as well as delay and reverb tails.. let's not forget the fact that you can not use plugins with latency, i.e logic's pdc engine, and then have any *track* automation on time, whatsoever. I mean those two are complete deal breakers. rewire ableton into PT perhaps is the answer for you and use the elastique pro in realtime. Did you try that? Then render in PT and close ableton, bingo, project is still all contained in PT.
Why Elastic Audio are not installed in Pro Tools 12? Elastic Audio not working :( | ChiLLoUt | Pro Tools 12 | 9 | 01-20-2018 12:56 PM |
Elastic Audio: X-Form vs. Disable Elastic Audio | sharchik | macOS | 1 | 09-22-2014 01:49 AM |
Render elastic audio alert when not using elastic audio! weird! | jjboogie | macOS | 7 | 03-26-2012 09:01 PM |
committing elastic audio in 7.4 is it fixed yet | 2fly | Pro Tools TDM Systems (Mac) | 9 | 01-15-2008 05:08 PM |
Elastic AUDIO, or Elastic TIME? | SoundWrangler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-13-2007 11:21 PM |
