Old 02-28-2015, 11:40 PM
Boe Larsen Boe Larsen is offline
Default D-command main module not working
Hm - this morning the D-command main fader module wont run. Faders and transport are working, but no light or function in everything else...
Kinda bad
Software issue?
Boe
Boe Larsen
Producer
www.millfactory.dk
Mac Pro 2x3.06ghz 12core. OWC SSD, 40gb ram,HDX2, UAD2, 2 x 16x16 HDi/o, 192D, D-command. OSX 10.11.6, PTHD 12.6.0
Old 03-01-2015, 12:18 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: D-command main module not working
Kinda bad
Software issue?
Boe
More likely hardware. First thing to check is the internal power supply board! Check all connections are seated. After that it's really going to be an electronic test engineer to find where the power has stopped in the circuitry or if something else has failed component wise.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 03-01-2015, 12:21 AM
Thanks Chris.
Boe Larsen
Producer
www.millfactory.dk
Old 03-01-2015, 12:46 AM
Buccanears's Avatar
Buccanears Buccanears is offline
Power supply/supplies. Definitely get it checked out by someone who knows what they're doing.
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 03-01-2015, 03:45 AM
JFreak's Avatar
JFreak JFreak is offline
Yep, but if you know how to use screwdriver you can open the thing yourself and then twiggle those connectors and if some connector is loose it'll wake up just like that.
Janne
Old 03-02-2015, 08:10 AM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Make sure you unplug the unit first so you don't fry yourself.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey
Alesis Masterlink, Alesis Adat LX20,
, Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon,
Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric.
http://www.johnackermusic.com/
protools@verizon.net
Live and Let Live
Old 03-02-2015, 09:38 AM
JFreak's Avatar
Yes. As usual, it's good to know where to touch and what to leave alone. If you have no clue, please don't even open the box.
Once you know for sure where the mains voltage is transformed to lower voltage, you can safely have the unit open and twiggle the low-voltage connectors and see which one brings it alive.
Janne
WTB: D-Command main unit jacko Buy & Sell 0 01-30-2015 06:47 AM
Main Module not working-Help icenet ICON & C|24 2 09-21-2013 01:01 PM
WTB D-Command ES Fader Module ec123 Buy & Sell 0 05-18-2013 11:20 AM
D-Command main unit and X-mon, HD3's,etc for sale Stylin' Audio Buy & Sell 23 03-14-2013 06:27 PM
D-Command main unit and X-mon Stylin' Audio Buy & Sell 4 10-27-2012 03:14 AM
