Old 02-13-2014, 12:44 PM
doubleyou26 doubleyou26 is offline
Default Omni HD and Sound Flower
I'm experimenting with an protocol for audio over IP called ipDTL. I've seen suggestions that Sound Flower will enable me to route ipDTL directly into Pro Tools.
I'm running Omni HD 10.3.7, the one demo I've seen about setting up Sound Flower couples it with regular PT 9.
Is anyone using Sound Flower with Omni HD successfully and could you share tips on making it work. I've tried but seem to be hitting a brick wall and honestly can't grasp what I'm doing wrong.
Thanks for your help and suggestions.
Wally
Old 02-14-2014, 12:32 PM
Chief Technician's Avatar
Arrow Re: Omni HD and Sound Flower
I don't think you will be able to do this. Sound Flower acts as a software audio interface. Unless you can create an Aggregate I/O device with Audio MIDI Setup that has both Sound Flower and the Omni, you are not going to be able to get Sound Flower I/O to work with the Omni.
Source-Elements has software (not free) that basically acts like Sound Flower and allows you to get audio into and out of Pro Tools. You may want to check their website for more details. I haven't use this software, I only know of its existence.
Old 02-14-2014, 01:20 PM
Default Re: Omni HD and Sound Flower
Thank you Johnathan. I'm familiar with the Source Elements software. I will probably have to implement it at some point. My interest in ipDTL stems from working with VO talent that has no need to use or purchase Pro Tools.
Wally
Old 02-14-2014, 08:24 PM
Jimmix Jimmix is offline
Just so you know, Source-Connect does not require its users to have Pro Tools. Its now avaiable as a standalone application. Also, they have a new version coming out that is using the Chrome browser as well. Its called Source-Connect Now.
If you want to record any application's output into Pro Tools Source-Nexus will do the trick. When ProTools is running with its own hardware, it does not share or aggregate it with any other hardware or driver. The only way in or out is via an aax plug-in. That is what Source-Nexus does. This will allow a browser driven codec like the new Source-Connect Now or any other application to be routed into and out of Pro Tools.
check out:
https://now.source-elements.com
and
http://source-elements.com/source-nexus/
I hope this helps.
No sound from OMNI ALT Monitor output! UnkleMik Pro Tools HDX & HD Native Systems (Mac) 4 11-18-2013 11:01 AM
New omni weird sound ilulilu888 Pro Tools HDX & HD Native Systems (Mac) 4 10-13-2012 08:50 PM
HD Omni how does the monitor section sound sonixstudio Pro Tools TDM Systems (Mac) 0 04-22-2012 04:03 AM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
HD Omni reviewed in Sound On Sound nst7 Pro Tools TDM Systems (Mac) 6 10-24-2010 11:56 AM
