Old 11-02-2011, 11:29 AM
digidesigner digidesigner is offline
Default Session sampling rate messup, what are my chances?
So the session should have been 48khz.
I created 48khz session and recorded audio into that, only realizing later, that my master clock was running at 44.1khz as I forgot to change that.
So now I have a session that "thinks" and "reads" it's 48khz but actually plays correctly if master clock is set at 44.1
How can I get the session to actually be 48khz as it needs to be, so I can forward the files?
Old 11-02-2011, 12:02 PM
Top Jimmy's Avatar
Default Re: Session sampling rate messup, what are my chances?
Import session data to a new 48K session. Select copy source media with sample rate conversion and set the source rate manually to 44.1K.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 11-02-2011, 10:39 PM
Thanks a lot!!
Anybody know what the max sampling rate of PT 8.0 LE is? Fabb2004 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-09-2012 10:58 PM
Where is 96000.0 Hz sampling rate? frcjt Pro Tools M-Powered (Mac) 10 10-17-2009 01:57 AM
Bit-Rate and Sampling Frequency change of a session??? Patill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-27-2009 07:11 AM
At which sampling rate are you recording? SoundReplay Tips & Tricks 28 07-10-2009 12:17 PM
16k sampling rate? guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-31-2007 03:03 AM
