Old 07-04-2007, 11:50 AM
carlg1212 carlg1212 is offline
Default Recording volume low, Mbox not in \"sound recording\"
It seems like every time I'm psyched to record, some new problem emerges.
I haven't changed anything, but now, when I record, the recording volume is very low. I can crank up my guitar and barely hear anything. The volume bar does move ever so slightly.
I noticed Mbox is not an option in the "sound recording" section of Windows' "sounds and audio devices properties".
Please help.
Old 07-06-2007, 08:34 AM
Default Re: Recording volume low, Mbox not in \"sound recording\"
Here's a question:
Should the Mbox appear as a recording device in the "Sounds and Audio Devices" in Windows' control panel?
Old 07-06-2007, 08:40 AM
spkguitar's Avatar
Here's a question:
No. The Wavedriver, which is what is used to connect to Windows to become a "default" audio device, is playback only. You cannot use any Digidesign LE device to record through the default windows device.
Only the Pro Tools drivers (used only by Pro Tools), and the ASIO drivers can be used for recording with a Digidesign LE device.
Old 07-08-2007, 08:13 AM
Ok, thanks. But do I have to re-install ProTools or something? I can no longer record anything (volume is extremely low). I don't know what happened. It used to work.
Old 07-08-2007, 08:51 AM
spkguitar's Avatar
To what position is the mix knob set?
If you could describe how you have everything set up, knob positions, session settings, track settings, input settings, etc, then it might be a lot easier to help you.
Old 07-12-2007, 06:34 AM
I've played around some more and switched my recording input to "IN2", and things seem to work, only now there is a strange echo when recording (when I only arm the track, everything sounds fine, it's when I hit "CTRL+spacebar" to start the actual recording does the echo occur). This has to be a latency issue, in my opinion.
How did this happen? Things were working fine, I was able to record to IN1 and everything worked, now all of a sudden, things have drastically changed.
Should I re-install ProTools? Any help is appreciated.
Old 09-19-2007, 02:32 PM
Well, I think my IN1 is blown on my Mbox. We've had some bad lightning storms over the summer, and eventhough my computer is protected by a fused surge protector, I think my Mbox still took a hit. That's my only conclusion.
IN1 doesn't work, IN2 works fine. I dunno.
Extremely Distorted Sound When Recording Through Mbox 2 TheEvilCow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 07-27-2010 11:49 PM
Mbox Mini 2 Sound Recording Problem Rebornalphawolf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-15-2010 01:32 PM
No "Sound Recording" option with Mbox 2 Mini ev_wagner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-04-2007 09:38 AM
Recording website sound via Mbox jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-16-2005 11:27 AM
Recording with mBox in Sound Forge er1c 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-14-2004 06:24 AM
