Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 06-01-2011, 11:15 PM
Dirt_ Dirt_ is offline
Default Re: Assuring your drum mics are in phase?
Oh wow I just noticed what the OP said about checking your cables. I spent a whole bight doing that once... And another entire evening FIXING cables I found wired wrong???!!! Seriously... How can a factory worker screw that up?
THERE'S ONLY THREE WIRES AND THE CONNECTORS ARE CLEARLY LABELLED???!!!
-Mac mini i7 Quad 2.3, 4g ram, OSX 10.10.2, PT11.2.1, iLok 2.
-Apogee Quartet, 2 Profire 2626's.
Old 08-28-2012, 11:08 PM
n8white n8white is offline
Default
Can you solo each drum mic and position it at the best sounding spot, track the kit, then time align after recording?
Old 09-13-2012, 02:23 AM
phatbeatstudio phatbeatstudio is offline
The quick easy way to tell if its in phase is.
toggle the polarity, if one way sounds fuller and deeper thats in phase.
Out of phase usually sounds thinner than in phase.
But if you do huge tracks .
Only nudge them in relation to the overheads. All other tracks but overheads or rooms should be gated or edited so there is no need to align tom 1 with tom 2 unless you have drastically diffent mic positioning affecting the times of the sound waves in relation to each other.
I think it is common practice to not align every drum to every drum if not completely impossible as I think albee was implying
Old 09-13-2012, 07:09 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Strictly speaking you can only be in or out of phase when 2 signals are exactly time aligned. When you're phase flipping direct mics against overheads, you really are just checking complimentary comb filtering.
5,1 Mac Pro Dual Hex Westermere 3.6Ghz, 24gig Ram, Pro Tools HD Native 2018.4, Sierra, Blackmagic Decklink HD Extreme 3D.
Phase issues with multiple lav mics Nemosonic Post - Surround - Video 11 07-31-2011 01:28 PM
drum mics Drunk Punk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 11-11-2005 09:02 AM
two mics on kick drum phase solution? thenewnoise Pro Tools TDM Systems (Mac) 7 11-01-2004 06:52 AM
How to make sure top and bottom mics are in phase? MaKoRancid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 07-04-2004 06:48 PM
Need more help with Drum Mics Please..... Big Tyme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 12-10-2002 12:17 AM
