Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 09-24-2020, 09:36 AM
nymills nymills is offline
Default Configuring PT & iZotope on the sound card
Using PT for video post/sound design. We have iZotope PP Suite/RX7. We're jumping between PT & RX7. Each takes over the audio engine forcing us to close one while the other works. We are working on a high-end laptop with studio speakers so no room for additional audio cards. What's the best practice, if any, to get them working simultaneously.
Thanks,
Michael
Old 09-24-2020, 09:52 AM
DontLetMeDrown DontLetMeDrown is offline
Default Re: Configuring PT & iZotope on the sound card
Ok this is going to sound like a weird solution but it’s the best I’ve found so far when you have 2 apps fighting for the ASIO driver.
Install the free demo for Image Line FL Studio. During installation there is the option to install “FL Generic ASIO” driver. Now when you launch PT, in the playback engine, you can choose the “FL ASIO Driver” which may require you to restart PT. Now open iZoptope RX and set it to use the same driver. Now you should be able to use both simultaneously.
Note- you’re unable to use all of your interface’s inputs and outputs when using this driver. That’s the biggest downside. The FL driver only sees 2 inputs and 2 outputs. Planning to make a video about this. Maybe I can do it tonight. This is also the method I’ve been using to playback Pro Tools sessions over Zoom calls.
Old 09-24-2020, 12:13 PM
Use RX Monitor plugin. Setup an Aux in Pro Tools and put the RX Monitor plugin on it. Then set the RX standalone audio driver to RX Monitor.
I am fixing dialog 99% of the time, so I have the RX Monitor return Aux in PT routed to my DX bus.
Scott Gatteño
Old 09-25-2020, 06:21 AM
daeron80 daeron80 is offline
Yep. Also, set the output of the RX Monitor aux track to a bus, and set the input of each relevant audio track to that same bus. When you're about to send a clip to RX, put the track in input first (Command I or Ctrl I, depending on the platform). That way, you'll hear the audio through all its plugins. Fix, send back, Command I, and continue.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 09-25-2020, 06:49 AM
Nice tip!
Scott Gatteño
Old 09-29-2020, 04:05 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
WOW!! Had NO idea that's what MONITOR was. Thank you... we've got three systems and had been taking the optical out of our MacPros and converting to AES, feeding it in to our monitoring systems. This is SO much better!!
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
vid card for PT11 and 2013 mac mini/ izotope 7 fork-media Post - Surround - Video 1 01-20-2020 07:07 AM
FS: IK/Softube/PA/SSL/Eventide/NI/iZotope/UVI/BBE Sound Proteinshake Buy & Sell 10 11-10-2018 04:43 AM
How do i make my digidesign sound card my dedicated sound card? Frankieballsss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-01-2016 11:09 PM
How do i make my digidesign sound card my dedicated sound card? Frankieballsss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-04-2003 05:04 PM
Configuring internal & external Cheetahs w/ an ATTO Ultra 160 card DaveCarlock Pro Tools TDM Systems (Mac) 13 04-05-2002 11:25 AM
