Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
  #31
Old 11-16-2018, 01:42 PM
UniversalAudio's Avatar
UniversalAudio UniversalAudio is offline
Universal Audio
Default Re: Universal Audio releases Apollo X TB3 interfaces.
Originally Posted by PatriotsBiker View Post
That gives me 4 days to find a cable.
https://help.uaudio.com/hc/en-us/art...3-USB-C-Cables
This might be helpful.
  #32
Old 11-16-2018, 02:05 PM
PatriotsBiker PatriotsBiker is offline
Originally Posted by UniversalAudio View Post
Thanks!
Unless I missed something, this looks like this qualifies.
https://www.amazon.com/gp/product/B078H9VQ5V
If not, I need to cancel veddy quickly.
  #33
Old 11-19-2018, 09:39 PM
I love holiday season deliveries. Late or early. Mine was early. Setup and test-tracking my SJ-200 90 minutes later. Not bad.
I don't even know where to start. My biggest motivator to buy is satisfied, but it wasn't my biggest gain. I can hear everything. Even some reference tracks that I didn't find that well represented by my rig are like listening for the first time.
Simply great.
  #34
Old 11-20-2018, 02:27 AM
Universal Audio
Simply great.
So happy to hear you're pleased!! Enjoy, and let me know if you have any questions.
  #35
Old 11-20-2018, 03:59 AM
Thanks, dm.
Sure is nice to get something that walks the talk. (so to speak)
  #36
Old 08-21-2020, 01:51 AM
skankytone skankytone is offline
1) the apollo x work perfectly with pro tools ultimate? especially apollox6
2) i have to disable "low latency" monitoring in protools when i mix inside ?(record finish) only enable it in record?
3) when i put the uad plug on insert in protools nothing to do the dsp are automatic work for the uad plug in the protools?
thanks have a good day
  #37
Old 08-23-2020, 10:44 AM
Universal Audio
1. yes.
2. Not necessarily. Only reason to disable LLM is if you want to do hardware inserts on the main out or you want to monitor "through PT".
3. Not sure what you're asking here, sorry. And sadly, our French is far worse than your English. :)
  #38
Old 08-23-2020, 07:34 PM
3. Yes when you use a UAD plugin in Pro Tools the processing for that Plugin runs on the UAD DSP. The actual plugin processing always runs on the DSP, never native, what looks like a native plugin just always launches processing on the DSP. It is not like TDM or HDX where you can run as native, it is DSP only. (Something I wish was not the case)
So...
You always need a UAD interface or other form of UAD DSP attached to the system to use those plugins.
If you run UAD plugins in Pro Tools and in the console they are sharing the same DSP resources and you need enough DSP to do both. You can end up needing lots of $$$ DSP power... to get stuff that could run native on a modern CPU... and they are nice but higher priced plugins so you make your choice and pays your money or not.
Running UAD plugins in Pro Tools require large buffer sizes for reliability, if you want to track through them at low latency... you would usually use them in the console not in Pro Tools.
There is lots to understand about plugin DSP plugin use, latency of some UAD plugins etc. Luckily UAD is amongst the best vendors with documentation.
  #39
Old 08-24-2020, 06:11 AM
Universal Audio
We'd recommend posting on our forum for the most help from other users.
http://www.uadforum.com
  #40
Old 07-06-2021, 02:59 PM
Hud Hud is offline
Hi Universal Audio, is there a simple link or pdf that shows how I can use UAD plug-ins with PTU? I’m exLogic + UAD user, have done a brief search but can’t find anything. Would be grateful! I use HD Native TB3 with Mtrx Studio on Mac Mini Big Sur.
Cheers H
FS: Universal Audio Apollo Twin Duo USB 3.0 joshuawade Buy & Sell 0 12-29-2017 12:00 PM
Universal Audio Apollo 8 vs Apogee Ensemble longname Third Party Interfaces 5 12-07-2015 01:46 PM
FS: Universal Audio Apollo Quad apesong Buy & Sell 3 09-09-2014 09:16 AM
Universal Apollo for Audio Post Nathan W. Post - Surround - Video 2 01-25-2014 08:47 AM
Universal Audio Apollo Quad drogan88 Buy & Sell 0 03-15-2013 08:22 AM
