Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 08-27-2018, 07:30 PM
abt abt is offline
Default Playback for windows and Pro Tools?
I think I know the answer to this, and it's not one that I like, but I'll try anyway.
I have a Surface Pro 4 that I use for travel. Pro Tools 2018 works fine on it with ASIO4ALL as the hardware driver. I want to be able to play windows audio at the same time, mostly mp4 videos.
Has anyone found a way to do this? I tried something called Synchronous Audio Router but that didn't work.
Any help much appreciated.
Old 08-28-2018, 02:13 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: Playback for windows and Pro Tools?
Hi !
That depends on of interface driver . Rigth now i have a Clarett Pre 8 X and i can work in Protools , play media player , vew youtbe etc . without any conflict or audio drop at all , but with my old digi003 this wasnt possible .
At least i dont know any 3rd party app to do this like the one you mention .
- Jesus Alvarado -
Keep the volume UP !
Old 08-28-2018, 06:38 PM
abt abt is offline
@jeam25 Thanks. The problem is I'm not taking an interface, I'm just using the internal sound card. ASIO4ALL works great, but it only likes one sound source at a time.
Old 08-29-2018, 10:17 AM
The Weed's Avatar
The Weed The Weed is offline
You can get an inexpensive interface for under 100 US that will be as good or better than your internal sound card. For many of us we have an interface and then use an actual mixer, a software mixer provided by the interface or a monitor controller to route the signal from the onboard soundcard to Pro Tools and/or our headphones/monitors.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 08-29-2018, 03:55 PM
abt abt is offline
Yes, an interface would be better, and I have a mobile interface, but I'm trying to avoid taking it. Even the smallest interface takes up space.
Pro Tools First/Windows 7 playback issue. Tonedog d' Bluescat Pro Tools | First Discussion 16 04-04-2016 10:55 AM
Headphones not allowing playback (Pro Tools 10.3 for Windows) clshelek Windows 3 01-04-2015 07:30 PM
Playback Problem: Overpowering Static Noise: Pro Tools can not get playback fast enou JLue Pro Tools 9 1 08-04-2011 09:59 AM
Pro Tools 8.0.4 Freezing (hard lock) during Playback in Windows 7 x64 Jennerstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-19-2010 02:37 PM
Mbox Playback with Windows XP Ryan_412 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-27-2004 11:01 PM
