digitest not showing cards
i'm using protoolsmix5.1 with a mac g4.the cards are seated properly and in the correct order...the leds on the cards are lit,but when i try to record i get dae error 6042
(pci bus too busy for dae communication) digitest does not list the cards. what could be wrong? |
Re: digitest not showing cards
Are you using a expansion chassis ?
If yes, see the compatibility lists how to install in the correct slots/ slotorder. I 've had this problem with a digi 13 slot chassis. They were not clear about whether to put the first card in slot 4 of bank 1 or 2. It should be bank 2 !!! Probably this is not of your concern... Secondly you can try to raise the DAE buffer size. Size 2 is recommended but I have put it on 4. You can also assign more RAM to DAE. Lower the H/W buffer size to 128 and set CPU usage limit to 65% Best to do is to go to the online answerbase and read about this error. I've just been there because i have DAE error 9073 and its kind of related to this one Hope this helps,cheers |
I don't know the correct slotorder with them (digitest always report misconfig) whever 1 d24 2 mixfarm 3 mixfarm 4 mixfarm 5 mixfarm 6 mixfarm 7 mixfarm 8 dspfarm 9-13 empty or 1 mixfarm 2 mixfarm 3 mixfarm 4 mixfarm 5 mixfarm 6 mixfarm 7 d24 8 dspfarm 9-13 empty Thanks Kenneth |
mix farms first, then the d24. also, make sure your set the 1000's of colors and you dont have any plug in windows on a second monitor.
New G5 not seeing HD cards In digitest | bryanbassett | Pro Tools TDM Systems (Mac) | 10 | 04-19-2007 02:13 PM |
New G5 not seeing HD cards In digitest | bryanbassett | Pro Tools TDM Systems (Mac) | 1 | 04-18-2007 03:05 PM |
DigiTest 5.0.1 doesn't see cards in G4(AGP), OS 9.0.2 | J. S. Bach | Pro Tools TDM Systems (Mac) | 6 | 03-23-2000 01:39 PM |
My cards Failed Digitest! | Zep Dude | Pro Tools TDM Systems (Mac) | 1 | 03-07-2000 10:19 PM |
Digitest doesn't see my cards | mario | Pro Tools TDM Systems (Mac) | 8 | 01-21-2000 09:33 PM |
