Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 10-12-2017, 05:22 AM
Default switching screens & screen sharing
In preparation for getting my iMac back up and running (it's at a shop for a diagnosis on what really happened - did my video card get fried) I've been doing a ton of research on various things. Mostly centered around running VEPro6 on two machines. I've got the basics down, putting things together piece-by-piece like a jigsaw puzzle. In this journey I've run into things I never did before on a Mac with the major one being screen sharing. Got that sussed.
Where I've run into a snag is when working in VEPro and switching screens back and forth. Saw a YouTube video where a fellow was doing just this and he had both the master and slave in full screen mode. He said he made a gesture setup on whatever pointing device he was using (didn't say what the device was) to make it easy to switch back and forth between the master where he had PT12 running and the slave with the VEPro server running. I'm not interested on the gesture as much as how does one actually switch back and forth between the two full screens? Understand that I've never used Spaces or Mission Control - is the switching accomplished using either or both of these two and if so how? If not the how to do the deed otherwise.
Jack
QAPLA!
Old 10-12-2017, 10:00 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: switching screens & screen sharing
I'm on PC. I have one monitor, keyboard and mouse and use a KVM switch to go from one computer to another, either with a keyboard shortcut or a button on the KVM box.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-12-2017, 11:31 AM
Thanks but doesn't help one bit. Mac specific and iMacs have a built-in screen.
Jack
QAPLA!
Screen sharing causing 9173 errors dankin Pro Tools 12 2 08-31-2015 01:25 PM
Screen Sharing - PT having issues when Overdubbing using VNC remote joeldadrummer macOS 15 01-12-2011 09:34 AM
Lets Talk Screen Sharing (Remote Control) therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-15-2010 10:19 AM
Screen sharing + Spinning Beachball ? T-Low Pro Tools TDM Systems (Mac) 8 03-25-2010 05:02 PM
usb sharing/switching device for use on ilok johnbhoy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-09-2009 04:35 PM
